2 Replies Latest reply on Feb 28, 2012 7:57 AM by Török Attila
    Flash Builder mobile - complex XML reading
    Török Attila
      Hello Developers,
      Please help me! I'm trying to develop a mobile app, that displays a complex xml file (i'm not a developer, so please be patient... ). Here's the xml file, then I write what I'd like to do:
      <?xml version="1.0"?>
      <server_status>
      <hosts>
         <host>
            <host_name>server1</host_name>
            <modified_attributes>0</modified_attributes>
            <check_command>check-host-alive</check_command>
            <check_period>24x7</check_period>
            <notification_period>24x7</notification_period>
         </host>
            <host>
            <host_name>server2</host_name>
         </host>
      </hosts>
      <services>
         <service>
            <service_description>C:\ Drive Space - Exchange Edge 1</service_description>
            <check_command>check_nt!USEDDISKSPACE!-l c -w 80 -c 90</check_command>
                </service>
                <service>
            <service_description>CPU Load - Exchange Edge 1</service_description>
            <check_command>check_nt!CPULOAD!-l 5,80,90</check_command>
                </service>
         <service>
            <service_description>C:\ Drive Space - Exchange Edge 2</service_description>
                </service>
         <service>
            <service_description>CPU Load - Exchange Edge 2</service_description>
                </service>
      </services>
      </server_status>
      As you can see, there's 2 main nodes: hosts & services. On the opening screen of the app I can list the hosts displaying in a list the host nodes with host_name. That's fine. I select one of them and on the new view I show the selected host attributes like <modified_attributes>, <check_period>, etc. What I want is to display on this screen the selected host's services. Under the <services> node there are 4 <service> child node: 2 services for host1 and 2 services for host2. I only want to list those services that are belong to the host I selected on the main view.
      Please write me the source code of the solution either here or in email (attila.toeroek@gmail.com)
      Thanks for your help!
        • 1. Re: Flash Builder mobile - complex XML reading
          Jakub Wojciechowski Level 1
          Providing that you are using list component for host selection the dataProvider for your view should look like
          dataProvider="{serverStatus.services.service.(host_name == list.selectedItem.host_name)}
          • 2. Re: Flash Builder mobile - complex XML reading
            Török Attila Level 1
            Really thanks for your reply, but I don't really know, where and how to put in the code. Here's the mxml:
            <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
                                xmlns:szolgaltatas="services.szolgaltatas.*"
                                title="DetailsView"
                                viewActivate="getDetails()"
                      <fx:Script>
                                <![CDATA[
                                          import mx.events.FlexEvent;
                                          [Bindable] private var ha:String;
                                          [Bindable] private var hb:String;
                                          [Bindable] private var hc:String;
                                          [Bindable] private var hd:String;
                                          import valueObjects.Host;
                                          import valueObjects.Service;
                                          private function getDetails():void
                                                    var thisItem:Host = data as Host;
                                                    ha = thisItem.last_time_up;
                                                    hb = thisItem.last_check;
                                                    hc = thisItem.plugin_output;
                                                    hd = thisItem.host_name;
                                          protected function textArea_creationCompleteHandler(event:FlexEvent):void
                                                    getDataResult.token = szolgaltatas.getData();
                      </fx:Script>
                      <fx:Declarations>
                                <s:CallResponder id="getDataResult"/>
                                <szolgaltatas:Szolgaltatas id="szolgaltatas"/> <!-- Szolgaltatas service -> getData(): Service[] -->
                      </fx:Declarations>
                      <s:Label top="10" left="10" right="10" text="Time Up: {ha}"/>
                      <s:Label top="30" left="10" right="10" text="Last Check: {hb}"/>
                      <s:Label top="50" left="10" right="10" text="Check Result: {hc}"/>
                      <s:Label top="90" left="10" right="10" text="Hostname: {hd}"/>
                      <s:TextArea id="textArea" left="10" right="10" bottom="10" height="50%"
                                                    creationComplete="textArea_creationCompleteHandler(event)"
            </s:View>
            Thank you Jakub!
