4 Replies Latest reply on Feb 29, 2012 2:05 AM by enricQ2
    Left Scrollbar ?
    enricQ2 Level 1
      I've looking for an easy way to move the scrollbar to the left.
      I've tried to override the function updateDisplayList for a custom list component,
      but it doesn't seem to work.
      It should be a simple customization, but I can not find the clue.
      Does anybody have a system to move it?
        • 1. Re: Left Scrollbar ?
          Jakub Wojciechowski
          I am using the same approach with overriding updateDisplayList and it works fine. You can check the code:
          protected override function updateDisplayList( unscaledWidth:Number, unscaledHeight:Number ):void{
              super.updateDisplayList( unscaledWidth, unscaledHeight );
              if( verticalScrollBar && verticalScrollBar.visible ){
                  verticalScrollBar.x = -verticalScrollBar.width;
          or mayby you are using spark list component ?
          • 2. Re: Left Scrollbar ?
            enricQ2 Level 1
            yes, at the moment I'm using only spark components, is this the problem I have then?
            • 3. Re: Left Scrollbar ?
              enricQ2 Level 1
              At the moment I'm trying to create a custom spark component extending skinnableContainer, with an VScrollBar.
              I suppose that will work.
              But it's very strange that there is not a easy solution for such a common problem in different languages.
              • 4. Re: Left Scrollbar ?
                enricQ2 Level 1
                I've found it really easy to do it with a custom component.
                You create a component with the content and an VScrollBar, and the you should assign the viewport of the VscrollBar to the content.
                I hope it will be useful for someone.
                <s:VScrollBar id="scrollBar" viewport="{contentGroup}"
                                                          visible="true" left="0" top="0" bottom="0">
                          </s:VScrollBar>
                    <!--- @copy spark.components.SkinnableContainer#contentGroup -->
                    <s:Group id="contentGroup" left="25" right="0" top="0" height="200"
                                               clipAndEnableScrolling="true">
                        <s:layout>
                            <s:BasicLayout/>
                        </s:layout>
                    </s:Group>
