1 Reply Latest reply on Apr 16, 2008 1:55 AM by RoboColum(n)
    Drop Down text using bullet from style
    amali720 Level 1
      I have a style that contains a bitmap bullet. If I create drop down text on that style, using a style that has numbering; when you view the drop down text in the compiled file it uses the bitmap from the drop down link style.
        • 1. Re: Drop Down text using bullet from style
          RoboColum(n) Level 5
          Hi mashpli and welcome to the RH community.
          If I understand you correctly you have created a bullet style that uses an image and then applied that style to some text in a drop down. You have then overridden the style by applying a number. This being the case, you will find that the (image bullet) style applied earlier is still referenced in the HTML code. This explains why the bitmap still appears.
          In this instance it is better to create a new numbered style in your style sheet and apply this to the drop down text.
