3 Replies Latest reply on Feb 29, 2012 9:51 AM by rafikibubu
    Control where findGrep and changeGrep is performed (ex. a specific textframe)
    rafikibubu Level 1
      Indesign cs5.5 ... MacOSX ... Javascript
      I'm getting very VERY close to figuring this blasted project out .. so any help on this issue would be most appreciated. (and to all who have already helped me get this far, thanks to you as well)
      Basically what I'm trying to do is pickup page numbers from a generated list (from an Indesign-made TOC), and insert those numbers as appropriate on page 2 of my document.
      I'm calling the generated table of contents "tocGen" ... and the supplied list "page2TOC"
      One by one, I need to pickup the town name and page number in tocGen, and replace those values with their matches in page2TOC. I'm trying to accomplish this with a series of findGrep() and changeGrep() methods.
      The first time through, it works great. It picks up "5\tBethel" from the tocGen, and puts it in place of "XX\tBethel" in the page2TOC.
      The second time I run the script, it ends up picking up the first line of the page2TOC ... instead of in tocGen, where it had during the first run. Makes sense, since that line is now the same format as the list in tocGen.
      So it would seem that if I could control where the first findGrep is directed, the script should move onto the next town each time I run it, without issue.
      So that's my question ... how do I point to a particular textFrame on a particular page for a findGrep and/or changeGrep?
      Kind of what would happen if I selected " Search: Story" on a normal find/change in Indesign:
      Thanks to any and all.
      Cheers,
      ~Nate
      Supplied list (on page 2)
      Fairfield County
      XX    Bethel (B)    01/27/2012
      XX    Bridgeport (W)    01/19/2012
      XX    Brookfield (W)    01/17/2012
      XX    Danbury (W)    01/26/2012
      XX    Darien (W)    01/17/2012
      XX    Easton (B)    01/13/2012
      XX    Fairfield (W)    01/12/2012
      XX    Greenwich (W)    01/26/2012
      XX    Monroe (W)    01/17/2012
      XX    New Canaan (W)    01/17/2012
      XX    New Fairfield (B)    01/13/2012
      XX    Newtown (W)    01/24/2012
      XX    Norwalk (W)    01/26/2012
      XX    Redding (B)    01/25/2012
      XX    Ridgefield (W)    01/09/2012
      XX    Shelton (W)    01/12/2012
      XX    Sherman (M)    12/30/2011
      XX    Stamford (W)    01/19/2012
      XX    Stratford (W)    01/20/2012
      XX    Trumbull (W)    01/19/2012
      XX    Weston (B)    12/28/2011
      XX    Westport (W)    01/13/2012
      XX    Wilton (W)    01/03/2012
      Generated list (on a master page):
      tocGen
      5    Bethel
      5    Bridgeport
      6    Brookfield
      7    Danbury
      7    Darien
      8    Fairfield
      8    Greenwich
      10    Monroe
      10    New Canaan
      11    Newtown
      11    Norwalk
      13    Redding
      13    Ridgefield
      13    Shelton
      14    Stamford
      17    Stratford
      18    Trumbull
      19    Westport
      My code thus far:
      // reference to tocGen text frame, an indesign generated table of contents
        var tocGenFrame  = document.masterSpreads.item("T-tocGen").pages.item(0).textFrames.item(0);
      // reference to page2TOC ... the supplied toc with the xx's
        var page2TOC  = document.masterSpreads.item("T-tocGen").pages.item(0).textFrames.item(0);
      app.findChangeGrepOptions.includeLockedLayersForFind = true;
      app.findChangeGrepOptions.includeLockedStoriesForFind = true;
      app.findChangeGrepOptions.includeHiddenLayers = true;
      app.findChangeGrepOptions.includeMasterPages = true;
      app.findChangeGrepOptions.includeFootnotes = true;
      //select generate TOC
      tocGenFrame.select();
      //grab current town and whole line (has page number and town)
             app.findGrepPreferences = app.changeGrepPreferences = null;
             app.findGrepPreferences.findWhat = "^\\d+\\t(.*)$";
      currentGen = app.activeDocument.findGrep();
      currentLine = currentGen[0].contents;
      currentMatch = currentGen[0].contents.match("^\\d+\\t(.*)$");
      currentTown = currentMatch[1];
             app.findGrepPreferences.findWhat = "^\\d+\\t"+currentTown+"$";
                    app.changeGrepPreferences.changeTo = "---";
                  app.activeDocument.changeGrep();
      // function that replaces "XX\tTown" with currentLine from above
      replaceTown();
      function replaceTown()
             app.findGrepPreferences.findWhat = "^XX\\t"+currentTown+" \\(";
             app.changeGrepPreferences.changeTo = currentLine+" \(";
         // $.writeln(currentXX);
