2 Replies Latest reply on Apr 17, 2008 12:54 PM by cfwild
    CFGRID Filter
    cfwild Level 1
      I have a CFGRID that uses a cfc to bind the data to the grid. So far so good. I also have an onchange function that allows you to update the grid. I've worked up a filter in a cfselect, with a bind coming from the cfc - function is getBrandsFilter.
      I'm trying to get the cfselect and the cfgrid to interact, such that when a filter is picked, the grid responds.
      Attached is the base page and the cfc:
      Any thoughts on how to make this work would be greatly appreciated!
      cfwild
        • 1. Re: CFGRID Filter
          Level 7
          update your cfgrid's bind attribute to:
          bind="cfc:brands2.getBrands({cfgridpage}, {cfgridpagesize},
          {cfgridsortcolumn}, {cfgridsortdirection}, {getBrandsFilter@change})
          update your getBrands method of brands2 cfc to accommodate the above
          change (i.e. query should have a where clause limiting the results to
          selected brand id)
          try that see how it goes - this is totally from memory, so may not be
          100% accurate...
          Azadi Saryev
          Sabai-dee.com
          http://www.sabai-dee.com/
          • 2. Re: CFGRID Filter
            cfwild Level 1
            Hi Azadi,
            Your response worked out perfectly. I'll post my changes, just in case anyone else reads this post.
            Thanks again!
            cfwild
