1 Reply Latest reply on Mar 6, 2012 8:45 AM by jtveter
    Channel.Call.Failed NetConnection.Call.Failed: HTTP: Status 500 with amfphp php and mysql
    jtveter
      I have been scripting a simple database connection to check login credentials and am comming accross these errors:
      Channel.Call.Failed
      HTTP: Status 500
      Any PHP code I run that is not connecting to MYSQL runs fine. But if I try to connect to the database thats what I get.
      Here is my mxml:
      <s:RemoteObject id="LogInService"
                                   source="Novus.NovusUser.getLogIn"
                                   destination="AMFPHP"
        fault="faultHandler(event)"
                                   showBusyCursor="true">
                                    <s:method name="getLogIn" result="onResult(event)" fault="faultHandler(event)"/>
      </s:RemoteObject>
      Which calls this actionscript:
      private function btn(event:Event):void
                                                   switch(event.target.id)
                                                             case "LogInSubmit":
        LogInService.getLogIn(UserName.text, PW.text)
                    break;
                                    private function onResult(result:ResultEvent):void
                                                   Alert.show("Result " + result.token.result);
                                                   if(result.token.result == true)
        currentState = "Main";
                                                   else
                                                             Alert.show(String(result.token.result));
                                    private function faultHandler(fault:FaultEvent):void
                                                   CursorManager.removeBusyCursor();
              var errorMessage:String = "code:\n" + fault.fault.faultCode + "\n\nMessage:\n" + fault.fault.faultString + "\n\nDetail:\n" + fault.fault.faultDetail;
                                                   Alert.show(errorMessage);
      and calls this PHP:
      If I comment out the database connection it returns a false value to me just fine but with it there it throws an error
      <?php
      class GetLogIn
                     private $_db;
                     public function getLogIn($U, $P)
                               //Connect To Database
                               $hostname='127.0.0.1';
                               $username='root';
                               $password='*********';    //not realy ***** blocked it out
                               $dbname='mydatabase';
                               try
                                              mysql_connect($hostname,$username, $password) OR DIE ('Unable to connect to database! Please try again later.');
                                              mysql_select_db($dbname);
                                              $sql = "Select * FROM empusr WHERE UserName = '$U' and Password = '$P'";
                                              mysql_close();
                                              if ($sql)
                                                             return true;
                                              else
                                                             return false;
                               catch
                                              return 'Unable to connect to database! Please try again later.';
      I have a crossdomain.xml but I am unsure if I have it placed right.
      I also have a services.conf but am unsure if that also needs to be altered to adjust for MySQL.
      Any help would be appreciated.
        • 1. Re: Channel.Call.Failed NetConnection.Call.Failed: HTTP: Status 500 with amfphp php and mysql
          jtveter Level 1
          Found the problum
          The connection string had to be placed in the public _constructor function of the class.
          <?php
          class EmployeeService
                    public function __construct()
                              $username='root';
                              $dbname='myDatabase';
                              mysql_connect($hostname,$username, $password);
                    public function logIn($N, $P)
                              $query = "SELECT * FROM EmpUsr WHERE UserName = '$N' AND Password = '$P'";
                              $result = mysql_query($query);
                                if ($result)
                                          return true;
                                else
                                          return false;
