1 Reply Latest reply on Feb 29, 2012 11:14 PM by Ventis85
    RTMFP direct peer-to-peer connection working on Windows XP, but not on Windows 7
    Ventis85 Level 1
      Hi all,
      we're having a strange problem on a project here. When we use NetConnection in combination with a NetGroup to initiate communication between two local AIR applications on Windows XP,  they always both connect to the NetGroup succesfully and detect each other as neighbors. However, on Windows 7 both applications connect succesfully to the NetConnection and NetGroup both don't detect each other as neighbors.
      To reproduce this problem, here are two AIR applications:
      RTMFP1:
      <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
          xmlns:mx="library://ns.adobe.com/flex/mx"
          applicationComplete="init()">
          <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <fx:Script>
              <![CDATA[
                  private var nc:NetConnection;
                  private var group:NetGroup;
                  [Bindable]
                  private var connected:Boolean = false;
                  private function init():void
                      connect();
                  private function connect():void
                      nc = new NetConnection();
                      nc.addEventListener(NetStatusEvent.NET_STATUS, netStatus);
                      nc.connect("rtmfp:");
                  private function netStatus(event:NetStatusEvent):void
                      writeText(event.info.code);
                      switch (event.info.code)
                          case "NetConnection.Connect.Success":
                              setupGroup();
                              break;
                          case "NetGroup.Connect.Success":
                              connected = true;
                              break;
                          case "NetGroup.Posting.Notify":
                              receiveMessage(event.info.message)
                              break;
                  private function setupGroup():void
                      var groupspec:GroupSpecifier = new GroupSpecifier("myGroup/groupOne");
                      groupspec.postingEnabled = true;
                      groupspec.ipMulticastMemberUpdatesEnabled = true;
                      groupspec.addIPMulticastAddress("127.0.0.1:30302");
                      group = new NetGroup(nc, groupspec.groupspecWithAuthorizations());
                      group.addEventListener(NetStatusEvent.NET_STATUS, netStatus);
                  private var i:int = 0;
                  private function sendMessage():void
                      var message:Object = new Object();
                      message.sender = group.convertPeerIDToGroupAddress(nc.nearID);
                      message.text = "Here's your message!";
                      message.random = i++;
                      group.post(message);
                  public function receiveMessage(message:Object):void
                      writeText(message.text);
                  private function writeText(txt:String):void
                      txtHistory.text += txt + "\n";
                  private function btnSend_clickHandler(event:MouseEvent):void
                      sendMessage();
          </fx:Script>
          <s:layout>
              <s:VerticalLayout/>
          </s:layout>
          <s:TextArea id="txtHistory"
              width="100%" height="100%"/>
          <s:Button id="btnSend"
              enabled="{connected}"
              label="Send message"
              click="btnSend_clickHandler(event)"/>
      </s:WindowedApplication>
      RTMFP2:
          applicationComplete="connect()">
          <fx:Declarations>
          </fx:Declarations>
          <fx:Script>
              <![CDATA[
                  [Bindable]
                              setupGroup();
                              break;
                              connected = true;
                              break;
                              break;
                  private function sendAcknowledge():void
                      message.text = "We received your message!";
                      message.sequence = i++;
                      sendAcknowledge();
                      textArea.text += txt + "\n";
          </fx:Script>
          <s:layout>
              <s:VerticalLayout/>
          </s:layout>
          <s:TextArea id="textArea" width="100%" height="100%"/>
      These applications can connect and send message to each other without a problem on Windows XP. On Windows 7 however, they cannot.
      Does anyone know why this wouldn't work on Windows 7 and what steps can be taken to make it work? It's critical to our project that this works.
      P.s.: In some cases, the applications take quite a long time to detect each other as neighbors (up to  15 seconds in some cases), in other cases they detect each other immediately. Does anyone know what could cause this delay?
