• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Search function oddity - any idea how to fix this?
New Here ,
Feb 29, 2012 Feb 29, 2012
We use RoboHelp in our call center for our procedure binder - works great, but we've found an odd search function problem. We have several different processes on how to handle our calls when a customer record can't be found and it's called "member not found". But when we try to search for the words "member not found" it returns a message saying "The words you typed is not a valid expression." It's causing us some headaches as it's a common search. Doesn't seem to happen for any other item we've searched for. Entering "not found" works, but not "member not found". Any idea why and how to fix this? Is this combination of words some odd programming language thing?
Views
587
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Mar 02, 2012 Mar 02, 2012
Welcome to the forum.
I just tested that in WebHelp and Microsoft HTML Help (CHM) in a RoboHelp 9 project and it works fine.
However, you haven't said what version of RoboHelp you are using and what type of help you are creating. Please see the Sticky Topic "Before You Post" and always start a thread with that information.
@petergrainge
Votes
Translate
Translate
Report
Report
New Here ,
Sorry about that. We are using RoboHelp 8 HTML.  The document is our procedure binder and has been in use for a while.  It's just this three-word phrase that seems to be the issue. (And the phrase is used throughout the document.)   I've attached a screen shot, if that helps.
Votes
Translate
Translate
Report
Report
Community Expert ,
Have you tried with the phrase in quotes?
@petergrainge
Votes
Translate
Translate
Report
Report
New Here ,
Mar 05, 2012 Mar 05, 2012
Yes, I did try quotes, but unfortunately, it didn't work either.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
I have just tested RoboHelp 8 as well and it still works.
Are both the project and the folder you are generating to on your hard disk?
If yes to both, create a new project with just a couple of topics and test that.
@petergrainge
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
