0 Replies Latest reply on Feb 29, 2012 10:18 AM by nikos101
    Help with listToCSV
    nikos101 Level 2
      I have an algorithm that works fine ,except when the text that is added as a csv element has new line characters(makes a jump in the excel) or comma, can anyone give me advice?
      Bolded where I think the solution should be
      package utils
          import flash.utils.Dictionary;
          import mx.collections.IList;
          import mx.utils.ObjectUtil;
           * This class contains static methods to be used to export to various formats
          public class Exporters
              public static function listToCSV(value:IList,delimeter:String):String
                  var str:String='';
                  var classInfo:Object=ObjectUtil.getClassInfo(value.getItemAt(0));
                  var properties:Array=classInfo.properties;
                  //get the headers
                  for (var k:int = 0; k < properties.length; k++)
                      str+=properties[k].toString() + delimeter;
                  str+="\n";
                  for each (var o:Object in value)
                      var prop:*;
                      for (var j:int=0; j < properties.length; j++)
                          prop=properties[j];
                          var thing:* = o[prop];
                          var isArray:Boolean=thing is Array;
                          var isDict:Boolean=thing is Dictionary;
                          var isBool:Boolean=thing is Boolean;
                          if (isArray)
                              str+="[]";
                          else if (isDict)
                              str+="{}";
                          else if (isBool)
                                  str+= thing?'YES':'NO';  //everyday users don't like 0 or 1
                          else
                              str+=  thing  == null?'null': thing.toString() ;
                              str+= delimeter;
                      str+="\n";
                  return str;
