2 Replies Latest reply on Mar 1, 2012 8:18 PM by Sathyamoorthi
    Need an expert advice on mx.Datagrid.
    Sathyamoorthi
           I have some doubts regarding datagrid. My application is in flex 3.5.
      1. Once i was not aware about itemEditor usage in datagrid. At that time i added itemrenderer and i set rendererIsEditor = 'true' to get itemEditor behaviour. Is that good to stay with rendererIsEditor or should i change itemRenderer to itemEditor to improve performance.
      2.I assigned very big XML to my datagrid. XML looks like this.
      <Root>
           <Row>
                <item1>value</item1>
                <item2>value</item2>
                <item3>value</item3>
                <item4>value</item4>
                <item250>value</item250>
           </Row>
           <Row>
           </Row>
      </Root>
      my xml contains 250 column values. but i allow maximum 10 columns to display at a time. user can customize datagrid column.
      my question is, if i assigned this big xml, will it degrade datagrid performance. shall i assign only 10 columns to dataprovider instead 250.
      if i assign only 10 values to dataprovider then i have to remove and add column values to dataprovider based on user customization.
      any valuable ideas?
