4 Replies Latest reply on Mar 4, 2012 11:33 PM by kc@dafolo.dk
    Execute .bat file from LC
    kc@dafolo.dk Level 1
      Hi all,
      I have a situation where I need to execute a .bat file from LC. Is that possible and how should I approach this?
      Thanks in advance
      Cheers
      Kim Christensen
      Dafolo A/S
        • 1. Re: Execute .bat file from LC
          $Nith$ Level 4
          Use the following syntax to execute the batch file.
          Runtime.getRuntime().exec("cmd /c start file.bat");
          • 2. Re: Execute .bat file from LC
            Hi Nith,
            I tried your suggestion – however it does not work as I expected. The process seems to execute – however nothing of what is in the bat file is done:
            E.g. I have this bat file – and when I run it with your suggestion in LC nothing happens – when I run it on the server I get the copy of the file:
            I have added the following in my Execute Script service action:
            Runtime.getRuntime().exec("cmd /c c:\\file.bat");
            The .bat file looks like this:
            ECHO OFF
            COPY "C:
            installer_debug.txt" "C:
            new_installer_debug.txt"
            PAUSE
            When I run the cmd /c c:\\echoName.bat in the "Run" window on the server it executes as expected, but not when I invoke the Process through Workbench.
            What am I doing wrong – do I need to setup something on my server (Systems is: JBoss Turnkey, MySQL,  LC 2.5)?
            \Kim
            • 3. Re: Execute .bat file from LC
              $Nith$ Level 4
              Your batch file should be placed in server or in a shared folder where the
              server has access.
              • 4. Re: Execute .bat file from LC
                Hi again,
                The .bat file is located here: c:\file.bat
                on the server.  When I invoke the process through Workbench nothing happens, but when I execute "cmd /c c:\file.bat" in "Run" on the server then the .bat file is executed.
                Cheers
                Kim Christensen
                Dafolo A/S
