1 Reply Latest reply on Mar 4, 2012 11:51 PM by Jayesh Sharma
    Text Highlighting issue with TextSnapshot object
    Jayesh Sharma
      I am working with a digital book application. I make use of swf loader to load swf pages created from pdf. I use TextSnapsot to draw inline text highlight on the pages. The highlight is thoroughly retained on the respective pages throughout the session and later it can be updated/deleted without any problem. Everything was working great till I made the following changes in the swf loading approach to enable page caching:
      I am now loading swf loader object into application memory and while doing jumping from one page to other page I am just copying the content of the next page to the current swf loader which is on the display to the user. There are two sets of swf loaders - one for displaying the page and other to cache the next/previous page(s). On the caching side, I load the swf into application memory and after getting it loaded I pick all the contents of the loaded swf page (the children of it's movie clip) into an array collection. While changing the page I copy the cached content into the swf loader's movie clip which is displaying the page.
      Now when I highlight on the page on display and navigate back/forth from the page and comeback again to the page where I did the highlighting: It shows the highlight I did. But as soon as I try to draw another highlight on that page, the previous highlight is instantly disappears from the page.
      I suspect that the Textsnapshot object which draws highlight while navigating (to the target display page) is different from the one which redraws/update the highlight on the same page next time. Although the Textsnapshot object id for both the objects is same.
      Here are some code snippet:
      For copying the content from the swf loader object cached in application memory:
              private function copyPageContent():void
                  var contentCollection:ArrayCollection = new ArrayCollection();
                  _pageContentVO = new PageContentVO();
                  _pageContentVO.contentHeight = MovieClip(_swfPageLoader.content).height;
                  _pageContentVO.contentWidth = MovieClip(_swfPageLoader.content).width;
                  var count:int = MovieClip(_swfPageLoader.content).numChildren;
                  for(var i:int=0;i<count;i++)
                      var dispObject:DisplayObject = MovieClip(_swfPageLoader.content).removeChildAt(0);
                      contentCollection.addItem(dispObject);
                  _pageContentVO.pageContentCollection = contentCollection;
                  _swfPageLoader = null;
      For copying the content to the swf loader which is displaying the page:
              private function copyContent(pageContentVo:PageContentVO):void
                  for(var i:int = 0;i<pageContentVo.pageContentCollection.length;i++)
                      var dispObject:DisplayObject = pageContentVo.pageContentCollection.getItemAt(i) as DisplayObject;
                      MovieClip(this.content).addChild(dispObject);
                  this.content.height = this.height;
                  this.content.width = this.width;
      after this I dispatch swf loader's complete manually and in the handler of that event I take the text snap shot object.(highlightManager.as)
      Code I use to draw highlight manually(using mouse drag on the page).
             public function setHighlight():void
                  removeAll();
                  if(_textSnapShot!=null && _textSnapShot.getText(0,_textSnapShot.charCount)!="")
                      if(_isCoveredTextSelectedAtAnyInstance)
                          _textSnapShot.setSelected(_beginIndex,_endIndex+1,false); //this is the global variable to the class
                      else
                          _textSnapShot.setSelectColor(0xfff100);
                          _textSnapShot.setSelected(_beginIndex,_endIndex+1,true);
                      if(saveHighlight)
                          countHighlightedSegments();
      Code I use to redraw previously drawn highlight when I return to the page:
             public function showHighlights(textSnapShot:TextSnapshot,currentPageNum:int):void
                  if(currentPageNum >= 0)
                      textSnapShot.setSelected(0,textSnapShot.charCount,false);
                      var pageVO:PageVO = _model.eBookVO.eBookPagesVO.getItemAt(currentPageNum) as PageVO;
                      var objColl:ArrayCollection = new ArrayCollection();
                      objColl.source = pageVO.highLightSelection;
                      for(var i:int=0;i<objColl.length;i++)
                          var highlightVO:HighlightVO = new HighlightVO();
                          highlightVO.beginIndex = objColl.getItemAt(i).beginIndex;
                          highlightVO.endIndex = objColl.getItemAt(i).endIndex;
                          setHighlightedSegment(textSnapShot,highlightVO.beginIndex,highlightVO.endIndex);
              private function setHighlightedSegment(textSnapShot:TextSnapshot,beginIndex:int,endIndex:int):void
                  textSnapShot.setSelected(beginIndex,endIndex,true);
      Looking forward to your support to resolve this issue.
      Regards,
      JS
