9 Replies Latest reply on Mar 2, 2012 9:44 AM by texmant123
    encoded movies have "moving details" vs original film
    texmant123 Level 1
      I have some DV footage that I captured with PrPro.  It captured at the standard capture sattings (720X480, 29fps, AVI)
      sequence settings are the default for (DV-24fps)  I chose this one so that I could have the sequence progressive instead of interlaced.
      The original AVI footage looks great.  When I play it with Windows media player OR PrPro video monitor.  As soon as I export it though, the video looses it's steady look.
      What I mean is that the detailed texture on the walls in the background start "dancing" and the whole thing just looks low quality.
      I've tried exporting with the following settings:
      1. "Match Sequence Settings"  you can see those above.
      2. MPG2 with the preset set to NTSC DV HQ (then I changed the interlacing to Progressive)
      3. H.264 with the preset set to YouTube SD (then I changed the interlacing to Progressive)
      I've tried 24fps and 29fps on all of the above and there is no difference in the outcome.
      I've also tried a new sequence set to DV NTSC settings and It all looks horrible  Please help!
      Thank you.
      Tex
