3 Replies Latest reply on Mar 8, 2012 7:23 AM by Carol L. Frampton
    Editable DataGrid with amount
    62ragtop Level 1
      I need to create a datagrid with one editable column of type amount. I'm using a textinput and I want
      1) on itemEditEnd format amount like "1.500,50"
      2) on itemEditBegin format amount like "1500.50"
      My problem is on itemEditBegin, here my code
      private function formatData(event:DataGridEvent):void {
      // Check the reason for the event.
      if (event.reason == DataGridEventReason.CANCELLED){
      return;
      var dataGrid:DataGrid = event.target as DataGrid;
      var col:DataGridColumn = dataGrid.columns[event.columnIndex];
      // Get the new data value from the editor.
      var newData:String = dataGrid.itemEditorInstance[col.editorDataField];
      // Determine if the new value is an empty String.
      if(newData == "") {
      return;
      if(event.dataField == "@GiacenzaEffettiva") {
      TextInput(dataGrid.itemEditorInstance).text = component.formatAmount(newData);
      private function unFormatData(event:ListEvent):void {
      // HERE dataGrid.editedItemRenderer IS NULL, WHY ?
      <mx:DataGrid id="dataGridId"
                  dataProvider
      ="{resultXMLListCollection}"
                  width
      ="1150"
                  rowCount
      ="20"
                  editable
      ="true"
                  selectable
      ="false"
                  itemEditEnd
      ="formatData(event)"
                  itemEditBegin
      ="unFormatData(event)">
      <mx:columns>
      <mx:DataGridColumn
                          id
      ="amountColumn"
                          width
      ="130"
                          headerText
      ="amount}"
                          dataField
      ="@amount"
                          editable
      ="{!flagDettaglio}"
                          editorDataField
      ="text"/>
      </mx:columns>
      mx:DataGrid>
      Can you help me ? Thanks
        • 1. Re: Editable DataGrid with amount
          Flex harUI Adobe Employee
          Try using a labelFunction to format the displayed data.
          • 2. Re: Editable DataGrid with amount
            62ragtop Level 1
            labelFunction is usefull to format amount like "1.500,50" but how can I format this filed like "1500.50" when I click on it ?
            • 3. Re: Editable DataGrid with amount
              Carol L. Frampton Level 2
              Here is a quick hack job on one of the examples to show it is possible to change the displayed text value when edited and then change it again after editing is completed.
                             xmlns:mx="library://ns.adobe.com/flex/mx">
                  <fx:Script>
                      <![CDATA[
                          import mx.events.DataGridEvent;
                          import mx.controls.TextInput;
                          import mx.controls.listClasses.IDropInListItemRenderer;
                          import mx.events.DataGridEventReason;
                         // Handle the itemEditBegin event.
                          private function myDataGrid_itemEditBeginHandler(event:DataGridEvent):void
                              // Get the name of the column being editted.
                              var colName:String = myDataGrid.columns[event.columnIndex].dataField;
                              if(colName=="amount")
                                  // Handle the event here.
                                  event.preventDefault();
                                  // Creates an item editor.
                                  myDataGrid.createItemEditor(event.columnIndex,event.rowIndex);
                                  // All item editors must implement the IDropInListItemRenderer interface
                                  // and the listData property.
                                  // Initialize the listData property of the editor.
                                  IDropInListItemRenderer(myDataGrid.itemEditorInstance).listData =
                                  IDropInListItemRenderer(myDataGrid.editedItemRenderer).listData;
                                  // Copy the cell value to the TextInput control.
                                  myDataGrid.itemEditorInstance.data = myDataGrid.editedItemRenderer.data;
                                  TextInput(myDataGrid.itemEditorInstance).text += " modified";
                          // Define the eventlistner for the itemEditEnd event.
                          public function myDataGrid_itemEditEndHandler(event:DataGridEvent):void {
                                  // Do not update cell.
                                  return;
                              var newData:String=
                                  TextInput(event.currentTarget.itemEditorInstance).text;
                              if(newData == "") {
                                  // do something
                                  return;
                              if(event.dataField == "amount") {
                                  TextInput(myDataGrid.itemEditorInstance).text= "1.500,50";
                                  if (myDataGrid.editedItemRenderer == null)
                                      trace("myDataGrid.editedItemRenderer is null");
                  </fx:Script>
                  <fx:Declarations>
                      <mx:ArrayCollection id="arrColl">
                          <mx:source>
                              <fx:Array>
                                  <fx:Object amount="8500.50" />
                                  <fx:Object amount="480.50" />
                                  <fx:Object amount="71.50" />
                              </fx:Array>
                          </mx:source>
                      </mx:ArrayCollection>
                  </fx:Declarations>
                  <mx:DataGrid id="myDataGrid"
                               dataProvider="{arrColl}"
                               editable="true"
                               itemEditBegin="myDataGrid_itemEditBeginHandler(event)"
                               itemEditEnd="myDataGrid_itemEditEndHandler(event)">
                      <mx:columns>
                          <mx:DataGridColumn dataField="amount"
                                             editable="true" />
                      </mx:columns>
                  </mx:DataGrid>
              </s:Application>
