2 Replies Latest reply on Mar 2, 2012 7:43 AM by PagePageUI
    TypeError: Error #1034: Type Coercion failed: button + IFocusManager
    PagePageUI
      I am writing an application that only uses the keyboard to navigate throught the components on a page.
      When the user presses the any arror key, the focus is set to the component that has focus.
      For example, i have a container that has several images layout, the user can navigate to the other images
      that container using the arror keys.
      First, i tried using images as the component to store the image but i found out that i could not set the focus on an
      images component. Then i used buttons and set the icon property to the source of the image and it worked fine.
      But then i made a botton component in another mxml file i named buttonImage so i could set the icon property in the
      main application file. When i run it and navigate to the button that is a button is buttonImagel file, i get an error.
      "TypeError: Error #1034: Type Coercion failed: cannot convert components::buttonImage@121ca15c1 to mx.managers.IFocusManagerComponent."
      Does anyone know how i can fix this issue? I would really appreciate it. Here's some of my code:
      buttonImage.mxml
      <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
          <s:Button
              width="160" height="220"
              icon="images/genre.png"
              focusColor="#28ff2b"/>
      </s:Group>
      MainApplication.mxml
      //this is the code in the script block
      switch(key)
                          case Keyboard.LEFT: //left keycode: 37
                              if((pattern.indexOf("content_container")) > 0)
                                  IFocusM.setFocus(nav_content_container[elem_id].left);
                                  drawInitialFocus(nav_content_container[elem_id].left);
                                  IFocusM.getFocus().drawFocus(true);
                                  focused_component = String(IFocusM.getFocus());
                                  trace('Focus is now on ' + focused_component);
      //this is the mxml code in the MainApplication.mxml
      <s:TileGroup id="content_container"
                       width="700" height="100%"
                       horizontalGap="20" verticalGap="20">
              <s:Button id="first" width="200" height="250" icon="images/charlottes_web.jpeg" focusColor="#28ff2b" focusThickness="4"/>
              <s:Button id="second" icon="images/bad_lieutenant.jpeg" focusColor="#28ff2b"/>
              <s:Button id="third" icon="images/caroline.jpeg" focusColor="#28ff2b"/>
              <s:Button id="fourth" icon="images/che.jpeg" focusColor="#28ff2b"/>
              <s:Button id="fifth" icon="images/date_movie.jpeg" focusColor="#28ff2b"/>
              <components:buttonImage id="last"/>
          </s:TileGroup>
      </s:Application>
