2 Replies Latest reply on Apr 16, 2008 8:34 AM by CFedarko
    Glossary Entries Formatting
    harooki2 Level 1
      Using RH7, WebHelp Pro
      I have glossary terms that are formatted with a CSS as maroon. When I drag them into a topic they come in as blue underlined. Any idea what's going on here?
        • 1. Re: Glossary Entries Formatting
          RoboColum(n) Level 5
          Have you created a new style for the glossary term or amended an existing one. Glossary terms are added as expanding hotspots so you may find that the style mirrors the "Expanding Hotspot" style in your style sheet. Change this and you will get what you want.
          • 2. Re: Glossary Entries Formatting
            CFedarko
            I recently had the same problem... if you look at your html code, towards the top (typically) there should be a line similar to <link rel=StyleSheet href="..\..\Amber.css">. If there is any style information just below that, delete those overriding codes and your styles should be fine.
