4 Replies Latest reply on Mar 12, 2012 2:40 AM by $Nith$
    Help required in accessing a file on shared path
    Shiva.Kosaraju Level 1
      I am trying to access a file present in a shared location using a custom component. When i run my Java code the file is accessible. But when i deploy the same code on livecycle as a custom component, the code is not able to access the file.
      The location of the file is as follows: \\Shiva\Test\tempExcel.xlsx
      The path string i use in Java code is: ////Shiva//Test//tempExcel.xlsx
      Can someone help me with this issue. Do i have to change the pattern of the file path when i am trying to access the file from adobe livecycle custom component?
      In case i need to provide permissions to livecycle for accessing the Excel sheet please suggest on how i should implement the same.
