1 Reply Latest reply on Apr 3, 2008 5:48 PM by ghempton
    Compiling CSS with a ClassReference
    asyncster
      I'm having problems with a (very) basic scenario involving compiling css to swf.
      In my project, I have a src/org/xyz folder, with two files:
      1) CoolBorder.as
      2) MySkin.css
      In MySkin.css, I have a class reference to CoolBorder:
      .buttonSyle
      borderSkin: ClassReference("CoolBorder");
      However, when I try to enable 'Compile CSS to SWF", I get the following error:
      "A file found in a source-path must have the same package structure '', as the definition's package, 'org.xyz'."
      Not deterred, I figure that I'll try to use mxmlc to do some good old fashioned command-line compiling. I go into my projects src directory, and type 'mxmlc org\xyz\CoolBorder.as', and I get the exact same error.
      The work-around is to have MySkin.css and CoolBorder.as in completely separate subtrees (i.e MySkin.css can't be anywhere in the src/ folder).
      Is there a way to keep CoolBorder.as and MySkin.as in the same folder? Or do you not believe this is valid scenario?
      Thanks!
      Mike
