3 Replies Latest reply on Mar 5, 2012 12:20 AM by venky_123
    Can not resolve a multiname reference unambiguously- OSMF build from scratch
    venky_123 Level 1
      Hi
      I am trying to build OSMF from scratch and I have been following the Building OSMF and OSMF based projects guide published by adobe.
      I've been doing everything by the guide but when I try to compile the project, which is the unmodified trunk from SVN, I get the following error (see below). I did a fair bit of googling but to no avail. Please Help me out!
          [compc] E:\OSMF\OSMF SVN\trunk\framework\OSMF\org\osmf\elements\f4mClasses\D
      RMAdditionalHeaderParser.as: Error: Can not resolve a multiname reference unambi
      guously. org.osmf.elements.f4mClasses:Base64Decoder (from E:\OSMF\OSMF SVN\trunk
      \buildtools\sdks\4.5.1\frameworks\libs\osmf.swc(org.osmf.elements.f4mClasses:Bas
      e64Decoder)) and org.osmf.utils:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\frame
      work\OSMF\org\osmf\utils\Base64Decoder.as) are available.
          [compc]
          [compc] E:\OSMF\OSMF SVN\trunk\framework\OSMF\org\osmf\elements\f4mClasses\M
      anifestParser.as(137): col: 26 Error: Access of undefined property DateUtil.
          [compc]
          [compc]                             manifest.startTime = DateUtil.parseW3CDT
      F(root.nmsp::startTime.text());
          [compc]                                                  ^
          [compc]
      anifestParser.as(680): col: 18 Error: Type was not found or was not a compile-ti
      me constant: Base64Decoder.
          [compc]
          [compc]                                     var decoder:Base64Decoder = new
      Base64Decoder();
          [compc]                                                 ^
          [compc]
      Thanks!!
        • 1. Re: Can not resolve a multiname reference unambiguously- OSMF build from scratch
          venky_123 Level 1
          This is my entire log on compilation-
          E:\OSMF\OSMF SVN\trunk>ant
          Buildfile: E:\OSMF\OSMF SVN\trunk\build.xml
          all:
          build:
          compile.osmf:
          clean-bin:
          build:
             [delete] Deleting: E:\OSMF\OSMF SVN\trunk\framework\OSMF\OSMF-build-config.tm
          p.xml
               [copy] Copying 1 file to E:\OSMF\OSMF SVN\trunk\framework\OSMF
              [compc] Loading configuration file E:\OSMF\OSMF SVN\trunk\framework\OSMF\OSM
          F-build-config.tmp.xml
          anifestParser.as: Error: Can not resolve a multiname reference unambiguously. or
          g.osmf.elements.f4mClasses:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\buildtools
          \sdks\4.5.1\frameworks\libs\osmf.swc(org.osmf.elements.f4mClasses:Base64Decoder)
          ) and org.osmf.utils:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\framework\OSMF\o
              [compc]
              [compc] E:\OSMF\OSMF SVN\trunk\framework\OSMF\org\osmf\elements\f4mClasses\B
          ootstrapInfoParser.as: Error: Can not resolve a multiname reference unambiguousl
          y. org.osmf.elements.f4mClasses:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\build
          tools\sdks\4.5.1\frameworks\libs\osmf.swc(org.osmf.elements.f4mClasses:Base64Dec
          oder)) and org.osmf.utils:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\framework\O
              [compc]
          ediaParser.as: Error: Can not resolve a multiname reference unambiguously. org.o
          smf.elements.f4mClasses:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\buildtools\sd
          ks\4.5.1\frameworks\libs\osmf.swc(org.osmf.elements.f4mClasses:Base64Decoder)) a
          nd org.osmf.utils:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\framework\OSMF\org\
              [compc]
              [compc]
              [compc]
          g.osmf.elements.f4mClasses:DateUtil (from E:\OSMF\OSMF SVN\trunk\buildtools\sdks
          \4.5.1\frameworks\libs\osmf.swc(org.osmf.elements.f4mClasses:DateUtil)) and org.
          osmf.utils:DateUtil (from E:\OSMF\OSMF SVN\trunk\framework\OSMF\org\osmf\utils\D
          ateUtil.as) are available.
              [compc]
              [compc]
              [compc]
              [compc]
              [compc]
              [compc]                                                  ^
              [compc]
              [compc]
          Base64Decoder();
              [compc]                                                 ^
              [compc]
          anifestParser.as(680): col: 38 Error: Call to a possibly undefined method Base64
          Decoder.
              [compc]
          Base64Decoder();
              [compc]
              [compc]
          ootstrapInfoParser.as(92): col: 17 Error: Type was not found or was not a compil
          e-time constant: Base64Decoder.
              [compc]
              [compc]                             var decoder:Base64Decoder = new Base64De
          coder();
              [compc]                                         ^
              [compc]
          ootstrapInfoParser.as(92): col: 37 Error: Call to a possibly undefined method Ba
          se64Decoder.
              [compc]
          coder();
              [compc]                                                             ^
              [compc]
          ediaParser.as(67): col: 16 Error: Type was not found or was not a compile-time c
              [compc]
              [compc]                     var decoder:Base64Decoder;
              [compc]                                 ^
              [compc]
          ediaParser.as(147): col: 19 Error: Call to a possibly undefined method Base64Dec
          oder.
              [compc]
              [compc]                             decoder = new Base64Decoder();
              [compc]                                           ^
              [compc]
          ediaParser.as(154): col: 19 Error: Call to a possibly undefined method Base64Dec
          oder.
              [compc]
              [compc]                                           ^
              [compc]
          ediaParser.as(187): col: 19 Error: Call to a possibly undefined method Base64Dec
          oder.
              [compc]
              [compc]                                           ^
              [compc]
          RMAdditionalHeaderParser.as(91): col: 17 Error: Type was not found or was not a
          compile-time constant: Base64Decoder.
              [compc]
          coder();
              [compc]                                         ^
              [compc]
          RMAdditionalHeaderParser.as(91): col: 37 Error: Call to a possibly undefined met
          hod Base64Decoder.
              [compc]
          coder();
              [compc]                                                             ^
              [compc]
          BUILD FAILED
          E:\OSMF\OSMF SVN\trunk\build.xml:15: The following error occurred while executin
          g this line:
          E:\OSMF\OSMF SVN\trunk\build.xml:22: The following error occurred while executin
          g this line:
          E:\OSMF\OSMF SVN\trunk\build.xml:53: The following error occurred while executin
          g this line:
          E:\OSMF\OSMF SVN\trunk\framework\OSMF\build.xml:14: The following error occurred
          while executing this line:
          E:\OSMF\OSMF SVN\trunk\buildtools\utils.xml:107: compc task failed
          Total time: 56 seconds
          • 2. Re: Can not resolve a multiname reference unambiguously- OSMF build from scratch
            Flex harUI Adobe Employee
            There’s a Base64Decoder in the rpc.swc.  You may need to modify the imports, libraries, or some code to get around the error.
            • 3. Re: Can not resolve a multiname reference unambiguously- OSMF build from scratch
              venky_123 Level 1
              Hi
              I had to remove this file to get it working - buildtools\sdks\4.5.1\frameworks\libs\osmf.swc
              Thanks!
