7 Replies Latest reply on Mar 3, 2012 10:21 AM by raj_at_cq
    NPE for currentDesign
    raj_at_cq
      All of a sudden we are seeing NPE on our pages with currentDesign which is set by <ca:defineObjects> taglib.
      currentDesign.getDoctype(currentStyle).toRequest(request);
      Any info as to why this would happen and better ways to avoid these kinds of issues for all objects the tablig defines.
      Rajesh
        • 1. Re: NPE for currentDesign
          Sham HC Level 7
          Hi Rajesh,
            Is it happening randomly ?  Restart the server and see if it helps.   Please file a daycare ticket with all the logs to investigate further.
          Sham
          • 2. Re: NPE for currentDesign
            reusr1
            I would venture a guess and say you are missing the
            /etc/designs/yourdesign/jcr:content node
            Ruben
            • 3. Re: NPE for currentDesign
              raj_at_cq Level 1
              I see the my node exists in this case
              /etc/designs/yourdesign/jcr:content node, but still getting NPE.
              Will raise a daycare ticktet if there is no quick solution by the way restart didnt help either and this is the first time it happened.
              • 4. Re: NPE for currentDesign
                Davide G Adobe Employee
                What is giving you NPE? currentDesign or getDoctype()?
                Davide
                • 5. Re: NPE for currentDesign
                  raj_at_cq Level 1
                  I see npe thrown at currentDesign.getDoctype(currentStyle).ToRequest(request);
                  From my compiled jsp class, which I believe is design is null.
                  • 6. Re: NPE for currentDesign
                    Post the full stacktrace.
                    • 7. Re: NPE for currentDesign
                      raj_at_cq Level 1
                      Here is the logs
                      (500)
                      The requested URL /content/homepage/en/index.html resulted in an error in /apps/common/components/page/globalbase/globalbase.jsp.
                      Exception:
                      org.apache.sling.api.SlingException:
                              at org.apache.sling.scripting.jsp.jasper.servlet.JspServletWrapper.handleJspExceptionInterna l(JspServletWrapper.java:563)
                              at org.apache.sling.scripting.jsp.jasper.servlet.JspServletWrapper.handleJspException(JspSer vletWrapper.java:499)
                              at org.apache.sling.scripting.jsp.jasper.servlet.JspServletWrapper.service(JspServletWrapper .java:451)
                              at org.apache.sling.scripting.jsp.JspServletWrapperAdapter.service(JspServletWrapperAdapter. java:59)
                              at org.apache.sling.scripting.jsp.JspScriptEngineFactory.callJsp(JspScriptEngineFactory.java :233)
                              at org.apache.sling.scripting.jsp.JspScriptEngineFactory.access$100(JspScriptEngineFactory.j ava:85)
                              at org.apache.sling.scripting.jsp.JspScriptEngineFactory$JspScriptEngine.eval(JspScriptEngin eFactory.java:453)
                              at org.apache.sling.scripting.core.impl.DefaultSlingScript.call(DefaultSlingScript.java:358)
                      <SNIP>
                              at org.apache.sling.engine.impl.SlingRequestProcessorImpl.dispatchRequest(SlingRequestProces sorImpl.java:320)
                              at org.apache.sling.engine.impl.request.SlingRequestDispatcher.dispatch(SlingRequestDispatch er.java:208)
                              at org.apache.sling.engine.impl.request.SlingRequestDispatcher.include(SlingRequestDispatche r.java:102)
                              at com.day.cq.wcm.core.impl.WCMComponentFilter$ForwardRequestDispatcher.include(WCMComponent Filter.java:381)
                              at org.apache.jsp.libs.foundation.components.primary.cq.Page.Page_jsp._jspService(Page_jsp.j ava:106)
                              at org.apache.sling.scripting.jsp.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
                              at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
                              at org.apache.sling.scripting.jsp.jasper.servlet.JspServletWrapper.service(JspServletWrapper .java:420)
                              ... 154 more
                      Caused by: java.lang.NullPointerException
                              at org.apache.jsp.apps.common.components.page.globalbase.globalbase_jsp._jspService(globalba se_jsp.java:180)
                              ... 180 more
                      Request Progress:
                            0 (2012-03-02 14:55:45) TIMER_START{Request Processing}
                            0 (2012-03-02 14:55:45) COMMENT timer_end format is {<elapsed msec>,<timer name>} <optional message>
                            1 (2012-03-02 14:55:45) LOG Method=GET, PathInfo=/content/homepage/en/index.html
                            1 (2012-03-02 14:55:45) TIMER_START{ResourceResolution}
                            6 (2012-03-02 14:55:45) TIMER_END{5,ResourceResolution} URI=/content/homepage/en/index.html resolves to Resource=JcrNodeResource, type=cq:Page, superType=null, path=/content/homepage/en/index
                            6 (2012-03-02 14:55:45) LOG Resource Path Info: SlingRequestPathInfo: path='/content//homepage/en/index', selectorString='null', extension='html', suffix='null'
                            6 (2012-03-02 14:55:45) TIMER_START{ServletResolution}
                            6 (2012-03-02 14:55:45) TIMER_START{resolveServlet(JcrNodeResource, type=cq:Page, superType=null, path=/content/homepage/en/index)}
                           38 (2012-03-02 14:55:45) TIMER_END{32,resolveServlet(JcrNodeResource, type=cq:Page, superType=null, path=/content/homepage/en/index)} Using servlet /libs/foundation/components/primary/cq/Page/Page.jsp
                           38 (2012-03-02 14:55:45) TIMER_END{32,ServletResolution} URI=/content//homepage/en/index.html handled by Servlet=/libs/foundation/components/primary/cq/Page/Page.jsp
                           38 (2012-03-02 14:55:45) LOG Applying Requestfilters
                           38 (2012-03-02 14:55:45) LOG Calling filter: org.apache.sling.bgservlets.impl.BackgroundServletStarterFilter
                           39 (2012-03-02 14:55:45) LOG Calling filter: org.apache.sling.portal.container.internal.request.PortalFilter
                           39 (2012-03-02 14:55:45) LOG Calling filter: org.apache.sling.rewriter.impl.RewriterFilter
                           39 (2012-03-02 14:55:45) LOG Calling filter: com.day.cq.wcm.core.impl.WCMRequestFilter
                           39 (2012-03-02 14:55:45) LOG Calling filter: org.apache.sling.i18n.impl.I18NFilter
                           39 (2012-03-02 14:55:45) LOG Calling filter: com.day.cq.theme.impl.ThemeResolverFilter
                           39 (2012-03-02 14:55:45) LOG Calling filter: com.day.cq.wcm.foundation.forms.impl.FormsHandlingServlet
                           39 (2012-03-02 14:55:45) LOG Calling filter: org.apache.sling.engine.impl.debug.RequestProgressTrackerLogFilter
                           39 (2012-03-02 14:55:45) LOG Calling filter: com..ecom.cq.bundle.helpers.internal.ParagraphsServletFilter
                           40 (2012-03-02 14:55:45) LOG Calling filter: com..ecom.cq.bundle.helpers.internal.CampaignsOverviewFilter
                           40 (2012-03-02 14:55:45) LOG Calling filter: com.day.cq.wcm.mobile.core.impl.redirect.RedirectFilter
                           41 (2012-03-02 14:55:45) LOG RedirectFilter did not redirect (MobileUtil.isMobileResource() returns false)
                           41 (2012-03-02 14:55:45) LOG Applying Componentfilters
                           41 (2012-03-02 14:55:45) LOG Calling filter: com.day.cq.wcm.core.impl.WCMComponentFilter
                           46 (2012-03-02 14:55:45) LOG Calling filter: com..ecom.cq.bundle.reporting.impl.ComponentPathWrappingFilter
                           70 (2012-03-02 14:55:45) LOG Found processor for post processing ProcessorConfiguration: {contentTypes=[text/html],order=5, active=true, valid=true, processErrorResponse=true, pipeline=(generator=Config(type=htmlparser, config=org.apache.sling.jcr.resource.JcrPropertyMap@5a431ae9), transformers=(Config(type=-reporting-links, config=org.apache.sling.jcr.resource.JcrPropertyMap@6b9be54a), Config(type=linkchecker, config={}), Config(type=mobile, config=org.apache.sling.jcr.resource.JcrPropertyMap@47ea9477), Config(type=mobiledebug, config=org.apache.sling.jcr.resource.JcrPropertyMap@79b93583), Config(type=client-library-script-rewriter, config=org.apache.sling.jcr.resource.JcrPropertyMap@6e6869e3), serializer=Config(type=htmlwriter, config={}))}
                           72 (2012-03-02 14:55:45) LOG Calling filter: com.day.cq.wcm.core.impl.WCMDebugFilter
                           72 (2012-03-02 14:55:45) TIMER_START{/libs/foundation/components/primary/cq/Page/Page.jsp#0}
                           96 (2012-03-02 14:55:45) LOG Including resource JcrNodeResource, type=/mktg/components/page/homepage, superType=null, path=/content/homepage/en/index/jcr:content (SlingRequestPathInfo: path='/content//homepage/en/index/jcr:content', selectorString='null', extension='html', suffix='null')
                           96 (2012-03-02 14:55:45) TIMER_START{resolveServlet(JcrNodeResource, type=/mktg/components/page/homepage, superType=null, path=/content/homepage/en/index/jcr:content)}
                          161 (2012-03-02 14:55:45) TIMER_END{65,resolveServlet(JcrNodeResource, type=/mktg/components/page/homepage, superType=null, path=/content/homepage/en/index/jcr:content)} Using servlet /apps//common/components/page/globalbase/globalbase.jsp
                          161 (2012-03-02 14:55:45) LOG Applying Includefilters
                          162 (2012-03-02 14:55:45) LOG Calling filter: com.day.cq.wcm.core.impl.WCMComponentFilter
                          165 (2012-03-02 14:55:45) LOG Calling filter: com..ecom.cq.bundle.reporting.impl.ComponentPathWrappingFilter
                          167 (2012-03-02 14:55:45) LOG Calling filter: com.day.cq.wcm.core.impl.WCMDebugFilter
                          167 (2012-03-02 14:55:45) TIMER_START{/apps//common/components/page/globalbase/globalbase.jsp#1}
                        10698 (2012-03-02 14:55:56) LOG SCRIPT ERROR: An exception occurred processing JSP page /apps//common/components/page/globalbase/globalbase.jsp at line 47
                        10698 (2012-03-02 14:55:56) TIMER_END{10531,/apps/common/components/page/globalbase/globalbase.jsp#1}
                        10717 (2012-03-02 14:55:56) LOG SCRIPT ERROR:
                        10717 (2012-03-02 14:55:56) TIMER_END{10645,/libs/foundation/components/primary/cq/Page/Page.jsp#0}
                        10739 (2012-03-02 14:55:56) TIMER_START{handleError:throwable=org.apache.sling.api.SlingException}
                        10889 (2012-03-02 14:55:56) TIMER_END{150,handleError:throwable=org.apache.sling.api.SlingException} Using handler org.apache.sling.servlets.resolver.internal.defaults.DefaultErrorHandlerServlet
                        10928 (2012-03-02 14:55:56) TIMER_END{10928,Request Processing} Dumping SlingRequestProgressTracker Entries
