14 Replies Latest reply on Mar 6, 2012 7:22 PM by taz291819
    Mercury Playback GPU Accelaration interlace H.264 encoding problem
    MontyPython Level 1
      I have just ,managed to get my MSI GT780 running NVidia GTX  560M video card switched over to use GPU playback in Premiere CS5.5.
      Problem is, when I render full HD 1080 25p AVCHD video, it playsback interlaced with lines across the screen yet the footage is progressive.
      Any ideas and help please?
        • 1. Re: Mercury Playback GPU Accelaration interlace H.264 encoding problem
          Harm Millaard Level 7
          Let me get this straight:
          • Source is progressive
          • Render is progressive
          • Monitor is progressive
          So how do you establish that the result is interlaced?
          • 4. Re: Mercury Playback GPU Accelaration interlace H.264 encoding problem
            Jim_Simon Level 9
            Where exactly are you viewing the result?  Is the export for computer, web or Blu-ray playback?
            • 5. Re: Mercury Playback GPU Accelaration interlace H.264 encoding problem
              MontyPython Level 1
              For the web. It could be somethong to do with .mts files (from Panansonic SD900) as mp4's from t he Canon 600D does have this effect after encoding.
              • 6. Re: Mercury Playback GPU Accelaration interlace H.264 encoding problem
                Jim_Simon Level 9
                OK.
                What mode are you shooting in with the Panasonic?  What are the specs of the media?
                Also, what are the specs of the sequence and what are your exact export settings?
                • 7. Re: Mercury Playback GPU Accelaration interlace H.264 encoding problem
                  MontyPython Level 1
                  General
                  Complete name                            : D:\AVCHDMXF\Video files\00595.MTS
                  Format                                   : BDAV
                  Format/Info                              : Blu-ray Video
                  File size                                : 5.51 MiB
                  Duration                                 : 2s 854ms
                  Overall bit rate mode                    : Variable
                  Overall bit rate                         : 16.2 Mbps
                  Maximum Overall bit rate                 : 18.0 Mbps
                  Video
                  Menu ID                                  : 1 (0x1)
                  Format                                   : AVC
                  Format/Info                              : Advanced Video Codec
                  Format profile                           : High@L4.0
                  Format settings, CABAC                   : Yes
                  Format settings, ReFrames                : 4 frames
                  Format settings, GOP                     : M=3, N=12
                  Codec ID                                 : 27
                  Duration                                 : 2s 800ms
                  Bit rate mode                            : Variable
                  Bit rate                                 : 15.2 Mbps
                  Maximum bit rate                         : 16.8 Mbps
                  Width                                    : 1 920 pixels
                  Height                                   : 1 080 pixels
                  Display aspect ratio                     : 16:9
                  Frame rate                               : 25.000 fps
                  Color space                              : YUV
                  Chroma subsampling                       : 4:2:0
                  Bit depth                                : 8 bits
                  Scan type                                : Interlaced
                  Scan order                               : Top Field First
                  Bits/(Pixel*Frame)                       : 0.293
                  Stream size                              : 5.06 MiB (92%)
                  Audio
                  Menu ID                                  : 1 (0x1)
                  Format                                   : AC-3
                  Format/Info                              : Audio Coding 3
                  Mode extension                           : CM (complete main)
                  Codec ID                                 : 129
                  Duration                                 : 2s 912ms
                  Bit rate mode                            : Constant
                  Bit rate                                 : 384 Kbps
                  Channel(s)                               : 6 channels
                  Channel positions                        : Front: L C R, Side: L R, LFE
                  Sampling rate                            : 48.0 KHz
                  Bit depth                                : 16 bits
                  Compression mode                         : Lossy
                  Delay relative to video                  : -80ms
                  Stream size                              : 137 KiB (2%)
                  Text
                  Menu ID                                  : 1 (0x1)
                  Format                                   : PGS
                  Codec ID                                 : 144
                  Duration                                 : 2s 336ms
                  Exporting:
                  Mainconcept H.264 1080 25p 12mbs 16:9
                  Profile - main
                  Level - 5.1
                  Render max deph
                  • 8. Re: Mercury Playback GPU Accelaration interlace H.264 encoding problem
                    taz291819 Level 1
                    Your source footage is interlaced, and the Mainconcept Encoder is basically removing fields to de-interlace.  IMO, this is not a good way to de-interlace.  You need to export the final video as interlaced, but use the Blu-Ray H.264 preset, as the regular H.264 preset doesn't output interlaced footage correctly (it still de-interalces it).
                    • 11. Re: Mercury Playback GPU Accelaration interlace H.264 encoding problem
                      MontyPython Level 1
                      Thanks but it puts it out as two files, one if m4v and wav. How do i render in that mode as a complete render of video and audio?
                      • 12. Re: Mercury Playback GPU Accelaration interlace H.264 encoding problem
                        taz291819 Level 1
                        After you select Blu-Ray H.264, at the bottom, click on the audio tab.  Change it from PCM to Dolby Digital.  Then click on the Multiplex tab, and select TS.  That'll make it output a single file.
                        Honestly, I don't know why it won't multiplex the video and audio when using PCM, but I wish it did.  You can use other software to mux the files into a single file, but it's nice having it all done at once.
                        • 14. Re: Mercury Playback GPU Accelaration interlace H.264 encoding problem
                          taz291819 Level 1
                          I'm glad it worked out for you.
                          I really wish Adobe, or Mainconcept, would fix the regular H.264 preset to work correctly.  De-interlacing video even when you tell it not to has been a bug for quite a while.  I don't know why this issue hasn't been fixed yet.
