2 Replies Latest reply on Mar 3, 2012 6:23 PM by Rick Gerard
    rendering in flv, size problem
      hi everyone,
      i am using the after effect cs5 version, and when chosing the flv rendering format, the rendered area of my composition changes.
      hence, when imported in flash, the working area around the imported item is not the same than the composition size in after effect.
      it it probably more clear with the screenshots i will attach to the document.
      when exported in quicktime it works fine, but i must have a transparent background, so i have to export it in flv to make it work
      if someone knows anything about this, any help would be welcome
      Capture d’écran 2012-03-03 à 13.02.13.pngCapture d’écran 2012-03-03 à 13.02.57.pngCapture d’écran 2012-03-03 à 13.03.28.pngCapture d’écran 2012-03-03 à 13.03.52.png
