8 Replies Latest reply on Mar 4, 2012 8:53 AM by kglad
    embedding swf in html with smaller size
    myqwer Level 1
      hi,
      I want to embed an swf file that is on a different server.
      The thing is that i want the swf to be shown at a smaller size (500X333 instead of 900X600 ).
      The problem is that when i change width&height, the swf gets cut-off instead of show shrinking it.
      I tried playing with the params, but couldn't get it to work.
      what am i suppose to set?
      Thank you
      p.s.
      I don't think it matters but it's a swf of a flex project.
        • 1. Re: embedding swf in html with smaller size
          use percents for the width and height instead of absolute values.
          • 2. Re: embedding swf in html with smaller size
            myqwer Level 1
            Thank you for your reply.
            Sadly, it still cuts the swf. I don't get it.
            Maybe there's something to do in the flex project itself?
            • 3. Re: embedding swf in html with smaller size
              copy and paste your html embed code using percents.
              • 4. Re: embedding swf in html with smaller size
                adninjastrator Level 4
                You can easily change the display size of the .swf by changing the dimensions in the <object> params. So depending on your HTML embed code, it would look something like this:
                <object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" width="500" height="333" id="test" align="middle">
                or
                <object type="application/x-shockwave-flash" data="test.swf" width="500" height="333">
                or the display dimensions may be hard coded in the swfobject code in the <head>... would have to see the exact embed code to be sure.
                Best wishes,
                Adninjastrator
                • 5. Re: embedding swf in html with smaller size
                  myqwer Level 1
                  Here's the code that just cuts the swf and doesn't shrink it like i want.
                  As I said it's a flex project. Can it be that the dimension are hard coded in the project itself (don't know if that what you meant)?
                  <object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000"
                                                codebase="http://fpdownload.macromedia.com/get/flashplayer/current/swflash.cab">
                                                <param name="movie" value="swfFile.swf" />
                                                <param name="quality" value="high" />
                                                <param name="bgcolor" value="#869ca7" />
                                                <param name="allowScriptAccess" value="always" />
                                                <embed src="swfFile.swf" quality="high" bgcolor="#869ca7"
                                                          width="500" height="333" align="middle"
                                                          play="true"
                                                          loop="false"
                                                          quality="high"
                                                          allowScriptAccess="always"
                                                          pluginspage="http://www.adobe.com/go/getflashplayer">
                                                </embed>
                            </object>
                  • 6. Re: embedding swf in html with smaller size
                    you're not using a percent.
                    • 7. Re: embedding swf in html with smaller size
                      Appreciate your comments kglad! and while I agree that you can also use percents, I disagree that you must use percent dimensions to resize.
                      I've never had problems using exact pixel dimensions to resize while using percents less than 100% can produce unexpected results.
                      Here is a page displaying an original 500x500 .swf and then resized using pixel dimension and resized using %.
                      The resizing code is the code used by myqwer above... works fine either way... just not the same result....
                      So while either method (pixel or %) works on most .swfs, something else is preventing it from working for myqwer.
                      http://www.sqis.net/resize_test2.html
                      myqwer, can you please post a link to the actual page, there may be something we are not seeing.
                      Best wishes,
                      Adninjastrator
                      • 8. Re: embedding swf in html with smaller size
                        you're right.
                        he should be using a scale parameter though i though showall was default:
                        <param name="scale" value="showall" />
                        scale="showall"
        play="true"
        loop="false"
        quality="high"
                                                      </embed>
                                  </object>
