1 Reply Latest reply on Mar 4, 2012 5:48 PM by utopian201
    What causes "Error saving report" error?
    utopian201
      Hi
      I am trying to generate the junit style test results using flex unit.
      The error log is:
      Buildfile: c:\Code\unittests\src\build.xml
      init:
         [delete] Deleting directory c:\Code\unittests\src\reports
          [mkdir] Created dir: c:\Code\unittests\src\reports
      main:
          [mxmlc] Loading configuration file C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.6\sdks\4.6.0\frameworks\flex-config.xml
          [mxmlc] C:\Code\unittests\build\unittests.swf is up-to-date and does not have to be rebuilt.
      test:
          [mxmlc] Required RSLs:
          [mxmlc]     http://fpdownload.adobe.com/pub/swz/flex/4.6.0.23201/framework_4.6.0.23201.swz with 1 failover.
          [mxmlc]     http://fpdownload.adobe.com/pub/swz/tlf/2.0.0.232/textLayout_2.0.0.232.swz with 1 failover.
          [mxmlc]     http://fpdownload.adobe.com/pub/swz/flex/4.6.0.23201/spark_4.6.0.23201.swz with 1 failover.
          [mxmlc]     http://fpdownload.adobe.com/pub/swz/flex/4.6.0.23201/sparkskins_4.6.0.23201.swz with 1 failover.
          [mxmlc]     http://fpdownload.adobe.com/pub/swz/flex/4.6.0.23201/mx_4.6.0.23201.swz with 1 failover.
          [mxmlc] C:\Code\unittests\build\unittests.swf (370343 bytes)
           [echo] gets to here0
      [flexunit] Validating task attributes ...
      [flexunit] Generating default values ...
      [flexunit] Using the following settings for the test run:
      [flexunit]      FLEX_HOME: [C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.6\sdks\4.6.0]
      [flexunit]      haltonfailure: [true]
      [flexunit]      headless: [false]
      [flexunit]      display: [99]
      [flexunit]      localTrusted: [true]
      [flexunit]      player: [flash]
      [flexunit]      port: [1024]
      [flexunit]      swf: [c:\Code\unittests\build\unittests.swf]
      [flexunit]      timeout: [60000ms]
      [flexunit]      toDir: [c:\Code\unittests\src\reports]
      [flexunit] Setting up server process ...
      [flexunit] Starting server ...
      [flexunit] Entry [c:\Code\unittests\build] already available in local trust file at [C:\Users\Ghost\AppData\Roaming\Macromedia\Flash Player\#Security\FlashPlayerTrust\flexUnit.cfg].
      [flexunit] Opening server socket on port [1024].
      [flexunit] Waiting for client connection ...
      [flexunit] Executing 'rundll32' with arguments:
      [flexunit] 'url.dll,FileProtocolHandler'
      [flexunit] 'c:\Code\unittests\build\unittests.swf'
      [flexunit]
      [flexunit] The ' characters around the executable and arguments are
      [flexunit] not part of the command.
      [flexunit]
      [flexunit] Client connected.
      [flexunit] Setting inbound buffer size to [262144] bytes.
      [flexunit] Receiving data ...
      [flexunit] Sending acknowledgement to player to start sending test data ...
      [flexunit]
      [flexunit]
      [flexunit] Stopping server ...
      [flexunit] End of test data reached, sending acknowledgement to player ...
      [flexunit] Closing client connection ...
      [flexunit] Closing server on port [1024] ...
      BUILD FAILED
      c:\Code\unittests\src\build.xml:68: java.util.concurrent.ExecutionException: Error saving report.
      at java.util.concurrent.FutureTask$Sync.innerGet(FutureTask.java:222)
      at java.util.concurrent.FutureTask.get(FutureTask.java:83)
      at org.flexunit.ant.tasks.TestRun.run(Unknown Source)
      at org.flexunit.ant.tasks.FlexUnitTask.execute(Unknown Source)
      at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
      at java.lang.reflect.Method.invoke(Method.java:597)
      at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
      at org.apache.tools.ant.Task.perform(Task.java:348)
      at org.apache.tools.ant.Target.execute(Target.java:390)
      at org.apache.tools.ant.Target.performTasks(Target.java:411)
      at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1399)
      at org.apache.tools.ant.Project.executeTarget(Project.java:1368)
      at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
      at org.apache.tools.ant.Project.executeTargets(Project.java:1251)
      at org.apache.tools.ant.Main.runBuild(Main.java:809)
      at org.apache.tools.ant.Main.startAnt(Main.java:217)
      at org.apache.tools.ant.launch.Launcher.run(Launcher.java:280)
      at org.apache.tools.ant.launch.Launcher.main(Launcher.java:109)
      Caused by: Error saving report.
      at org.flexunit.ant.report.Report.save(Unknown Source)
      at org.flexunit.ant.FlexUnitSocketThread.processTestReport(Unknown Source)
      at org.flexunit.ant.FlexUnitSocketThread.parseInboundMessages(Unknown Source)
      at org.flexunit.ant.FlexUnitSocketThread.call(Unknown Source)
      at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
      at java.util.concurrent.FutureTask.run(FutureTask.java:138)
      at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
      at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
      at java.lang.Thread.run(Thread.java:662)
      Caused by: java.io.FileNotFoundException: c:\Code\unittests\src\reports\TEST-scheduledTaskSuite.tests.TestCase1.xml (The requested operation cannot be performed on a file with a user-mapped section open)
      at java.io.FileOutputStream.open(Native Method)
      at java.io.FileOutputStream.<init>(FileOutputStream.java:194)
      at java.io.FileOutputStream.<init>(FileOutputStream.java:145)
      ... 9 more
      Total time: 8 seconds
      C:\Code\unittests\src>
      The error at the bottoms says it could not find the file TestCase1.xml, but I checked the reports folder and TEST-scheduledTaskSuite.tests.TestCase1.xml is indeed there.
      I have a total of 14 tests and sometime there are two reports generated, sometimes 7, but it appears it is a timing issue as a random number of reports out of the 14 are generated each time.
