2 Replies Latest reply on Mar 6, 2012 11:20 AM by czigany
    How to get sprite number in a KeyUp script?
    czigany Level 1
      I have an app with a series of text entry fields. Users enter numeric values in each field. I want to have the keyboard focus move to the next field when the user clicks on the Enter key. So far I've only been able to do this by hard coding the number of the next sprite as follows...
        case(_key.keycode) of
          36:  --Enter key
            _movie.keyboardFocusSprite = 64 -- This is the hard-coded value of the next sprite
            numString = member("ALA_CFTHolder").text
          otherwise: -- Handles ordinary input
        end case
      I want to find a way to move to the next sprite without hardcoding the value. I've tried reading the _movie.keyboardFocusSprite but it's always -1. Surely there's a way to do this.
      Thanks.
        • 1. Re: How to get sprite number in a KeyUp script?
          Mister MUX Level 2
          See if this code helps you. It doesn't matter which sprite channel the fields are in, but the focus order is determined by the order in which the sprites appear on the score. If that isn't what you want a different approach will be required.
          property spriteNum, pEntrySpriteList
          on beginSprite me
            pEntrySpriteList = []
            sendAllSprites(#updateEntrySpriteList, spriteNum)
          end
          on updateEntrySpriteList me, senderSpriteNum
            pEntrySpriteList.add(senderSpriteNum)
            if spriteNum <> senderSpriteNum then sprite(senderSpriteNum).pEntrySpriteList.add(spriteNum)
          end
          on keyDown me
            case(the keycode) of
              36:  --Enter key
                myIndex = pEntrySpriteList.findPos(spriteNum)
                if myIndex = pEntrySpriteList.count then
                  the keyboardFocusSprite = pEntrySpriteList[1]
                else
                  the keyboardFocusSprite = pEntrySpriteList[myIndex + 1]
                end if
                pass
            end case
          end
          • 2. Re: How to get sprite number in a KeyUp script?
            czigany Level 1
            Thanks. This example is very useful.
