4 Replies Latest reply on Oct 17, 2012 10:21 AM by garyhatt
    Lock / Freeze Current Date after saving
    SIgloi
      Hello,
      Is there a way to lock the 'current date' field after it was saved the first time??
      At the moment the field updates every time the form is opened.
      I am using this (from the custom object library):
      form1.#subform[0].CurrentDate::ready:layout - (FormCalc, client)
      // Current Date in short-style date format.
      $.rawValue
      Thank you
      Simon
        • 1. Re: Lock / Freeze Current Date after saving
          SIgloi Level 1
          What is should read is this
          $.rawValue EQUALS num2date(date(), DateFmt(1))
          • 2. Re: Lock / Freeze Current Date after saving
            radzmar Adobe Community Professional & MVP
            wrap you code into an if expression at the initialize event.
            The date then will only be populated, if the field is empty.
            if ($.isNull) then
                      $ = Num2Date(date(), DateFmt(1))
            endif
            • 3. Re: Lock / Freeze Current Date after saving
              AekCLtd Level 1
              Worked like a charm.  thanks so much!
              • 4. Re: Lock / Freeze Current Date after saving
                garyhatt Level 1
                I need to use this same code, and it is working like I need. The problem I am having is that now when I use the Submit button, I am getting a "Date validation failed" error message. I don't have any validation on this field, so any thoughts as to where it is coming from? I do have this code to validate other fields, which all work with no errors:
                if (form1.Tailboard.Supervisor.rawValue == null)
                            xfa.host.messageBox("Choose a supervisor from the list.", "", 0);
                            xfa.host.setFocus("form1.Tailboard.Supervisor");
                if (form1.Tailboard.Header.Table1.Row1.PersonInCharge.rawValue == null)
                            xfa.host.messageBox("Enter the name of the Person in Charge.", "", 0);
                            xfa.host.setFocus("form1.Tailboard.Header.Table1.Row1.PersonInCharge");
                if (form1.Tailboard.Header.Table1.Row1.WorkLocation.rawValue == null)
                            xfa.host.messageBox("Enter a Work Location/Structure Number.", "", 0);
                            xfa.host.setFocus("form1.Tailboard.Header.Table1.Row1.WorkLocation");
                if (form1.Tailboard.Review.Review1.Review1.rawValue == null)
                            xfa.host.messageBox("Check 'YES' that you have completed task 1.", "", 0);
                            xfa.host.setFocus("form1.Tailboard.Review.Review1.Review1");
                if (form1.Tailboard.Review.Review2.Review2.rawValue == null)
                            xfa.host.messageBox("Check 'YES' that you have completed task 2.", "", 0);
                            xfa.host.setFocus("form1.Tailboard.Review.Review2.Review2");
                if (form1.Tailboard.Review.Review3.Review3.rawValue == null)
                            xfa.host.messageBox("Check 'YES' that you have completed task 3.", "", 0);
                            xfa.host.setFocus("form1.Tailboard.Review.Review3.Review3");
                if (form1.Tailboard.Review.Review4.Review4.rawValue == null)
                            xfa.host.messageBox("Check 'YES' that you have completed task 4.", "", 0);
                            xfa.host.setFocus("form1.Tailboard.Review.Review4.Review4");
                if (form1.Tailboard.Review.Review5.Review5.rawValue == null)
                            xfa.host.messageBox("Check 'YES' that you have completed task 5.", "", 0);
                            xfa.host.setFocus("form1.Tailboard.Review.Review5.Review5");
                else if (form1.Tailboard.Supervisor.rawValue != null &&
                            form1.Tailboard.Header.Table1.Row1.PersonInCharge.rawValue &&
                            form1.Tailboard.Header.Table1.Row1.WorkLocation.rawValue &&
                            form1.Tailboard.Review.Review1.Review1.rawValue &&
                            form1.Tailboard.Review.Review2.Review2.rawValue &&
                            form1.Tailboard.Review.Review3.Review3.rawValue &&
                            form1.Tailboard.Review.Review4.Review4.rawValue &&
                            form1.Tailboard.Review.Review5.Review5.rawValue != null){
                            RealEmail.event__click.submit.target = "mailto:" + form1.Tailboard.Supervisor.rawValue + "?subject=" + "SJO" + " — "
                            + form1.Tailboard.Supervisor.formattedValue + " — "
                            + form1.Tailboard.Header.Table1.Row1.Date.rawValue;
                            RealEmail.execEvent("click");
