1 Reply Latest reply on Mar 6, 2012 2:44 PM by a-fro
    Best practices for setting environment based static variables?
    a-fro Level 1
      I have a set of static string variables that hold the url location of modules in a project. These locations change depending on whether I'm building for development, staging or production.
      What's the best way to set static variables in this way?
        • 1. Re: Best practices for setting environment based static variables?
          a-fro Level 1
          I don't know if this is best practice, but here's the solution I've come up with.
          The root domain is accessible within the swf via a node on a loaded xml file. So I created a simple method that sets a url variable based on that domain node.
          The domain-based url variable is then used within the static string variables that define the location of the modules.
          Simplified like so:
          var domain:String = xml.node.value;
          static var bucketLocation:String = getLocation()
          static var moduleLocation:String = bucketLocation + "modulename.swf";
          function getLocation():String
               var loc:String
               switch (domain) {
                    case stagingUrl:
                        loc = "pathToAmazonStagingBucket";
                         break;
                    case productionUrl:
                         loc = "pathToAmazonProductionBucket";
                         break;
