0 Replies Latest reply on Mar 6, 2012 6:00 AM by kkudiksx
    Flex 4.5 - Cairngorm Module Support error with creationComplete
    kkudiksx Newcomer
      Hi
      As a starting point I've already posted a thread (see link below)
      http://forums.adobe.com/thread/970855?start=0&tstart=0
      but I've had no luck in solving this.
      I have an mx:Application which loads a module defined in ShellContext(see below) using a ParsleyModuleDescriptor and is loaded using Cairngorn's ModuleViewLoader with BasicLoadPolicy.
      The module loads fine, however the module's children/components are not initialized correctly.
      The module is called DashboardModule. Its creationComplete handler is invoked last.
      The DashboardModule contains DashboardView and DashboardView's creationComplete also gets invoked second to last,
      however DashboardView's children's creationComplete never get invoked.
      So in particular, in DashboardView, the mx:ApplicationControlBar, the mx:Button, and the presentation:DashboardSearchView, presentation:DashboardMyApproval etc etc, are all initialized ( i can see the traces that are added there) but their creationComplete handlers never get invoked.
      I have tried adding creationPolicy="all", at application level, at module level and at component level with no luck.
      I have spent 2 whole days on this and I still haven't been able to figure out the problem.
      We've used cairngorm modules before with Parsley and Flex 4.5.1 and we've never had such a problem.
      To be more precise, I have the following configuration:
      ---ShellContext
      <fx:Object>
              <commonPresentation:NavigationHandlerPM id="navigationPM"/>
              <module:ParsleyModuleDescriptor objectId="dashboard"
                  url="DashboardModule-1.0-SNAPSHOT.swf"
                  applicationDomain="{ ClassInfo.currentDomain }"/>
      </fx:Object>
      --DashboardModule.mxml
      <mx:Module
          width="100%" height="100%"
          backgroundColor="white"
          horizontalAlign="left"
          verticalAlign="top"
          layout="vertical" verticalScrollPolicy="off" horizontalScrollPolicy="off"
                creationComplete="creationComplete();"
          xmlns:mx="library://ns.adobe.com/flex/mx"
          xmlns:fx="http://ns.adobe.com/mxml/2009"
          xmlns:spicefactory="http://www.spicefactory.org/parsley"
          xmlns:cairngorm="com.adobe.cairngorm.*"
          xmlns:presentation="com.test.presentation.*">
          <fx:Declarations>
              <spicefactory:ContextBuilder id="spiceFactoryContextBuilder">
                                    <cairngorm:CairngormModuleSupport/>
                                    <cairngorm:CairngormIntegrationSupport/>
                                    <cairngorm:CairngormNavigationSupport/>
                                    <spicefactory:FlexConfig type="{DashboardContext}"/>
                                    <spicefactory:ViewSettings autowireComponents="true"/>
              </spicefactory:ContextBuilder>
              <spicefactory:FastInject  property="model" type="{DashboardPM}"/>
              <spicefactory:Configure/>
          </fx:Declarations>
          <fx:Script>
              <![CDATA[
                  [Bindable]
                  [Inject(id="dashboardPM")]
                  public var model:DashboardPM;
                  private function creationComplete():void
                      trace('i should be called last god damn it');
                      model.startLoading();
          </fx:Script>
          <mx:VBox
              verticalScrollPolicy="off" horizontalScrollPolicy="off">
              <presentation:DashboardView
                  width="{this.width}" height="{this.height}"
                  verticalScrollPolicy="on" horizontalScrollPolicy="on"
                  userProfile="{shell.userProfile}"/>
          </mx:VBox>
      </mx:Module>
      ----DashboardView.mxml
      <mx:VBox
          creationComplete="createComplete()"
          xmlns:presentation="com.db.paragon.common.module.dashboard.presentation.*">
          <fx:Declarations>
          </fx:Declarations>
         <fx:Script>
              <![CDATA[
              import mx.core.FlexGlobals;
              import mx.utils.StringUtil;
              [Bindable]
              [Inject]
              public var searchModel:DashboardSearchPM;
              [Bindable]
              private var _userprofile:UserProfile;
              public function get userProfile():UserProfile {
                  return this._userprofile;
              public function set userProfile(userPr:UserProfile):void {
                  this._userprofile = userPr;
                  setUserWelcomeString();
              public function createComplete():void {
                    trace('i should be called second to last');
          </fx:Script>
          <mx:ApplicationControlBar
                  initialize="trace('initialise control bar');" creationComplete="trace('controlbar complete');"
              width="100%"
              horizontalAlign="right"
              verticalAlign="middle">
              <mx:Text
                  width="97%"
                  left="10"
                  fontSize="14"
                  fontThickness="12"
                  fontWeight="bold"
                  textAlign="left"
                  selectable="false" text="{userWelcomeString}"/>
              <mx:LinkButton id="help"
                  width="60"
                  color="gray"
                  textAlign="right"
                  label="Help"
                  click='navigateToURL(new URLRequest(urlToHelp));'/>
          </mx:ApplicationControlBar>
          <mx:Button initialize="trace('initialise button')" creationComplete="trace('button complete');"/>
          <presentation:DashboardSearchView initialize="trace('initializesearchview');" creationComplete="trace('searchviewcomplete');" creationPolicy="all"/>
          <presentation:DashboardMyApproval initialize="trace('initializeapproval');" creationComplete="trace('approvalcomplete');" creationPolicy="all"/>
          <presentation:DashboardPendingApproval initialize="trace('pendingapproval');" creationComplete="trace('pendingapprovalcomplete');" creationPolicy="all"/>
          <presentation:DashboardReviewsDue initialize="trace('reviewsdue');" creationComplete="trace('reviewsdue');" creationPolicy="all"/>
          <presentation:DashboardHistCreditApplications initialize="trace('histcreditapps');" creationComplete="trace('histcredcomplete');" creationPolicy="all"/>
          <presentation:DashboardRatingWriteups initialize="trace('ratingwriteups');" creationComplete="trace('ratingwriteupslcomplete');" creationPolicy="all"/>
          <presentation:DashboardNotifications initialize="trace('notifications');" creationComplete="trace('notificationscomplete');" creationPolicy="all"/>
      </mx:VBox>
      Any help is greatly appreciated.
