1. Re: Does anyone know where I can find an .inx file that would bring in the arabic language?
Joel Cherney Mar 6, 2012 1:40 PM (in response to iBabs2)I have seen a brilliant writeup somewhere of how languages get added to that dropdown, but I can't recall at all where it is. The shortcuts I use are either "place a Word doc that has text marked as Arabic" or "process INX/IDML through a tool like SDL Trados that has Arabic support."
I've never seen those fonts before, and a web search for the filenames reveals this thread, and not much else. Not a good sign.
Also, seeing the name "Lig" in a font doesn't inspire confidence; that's what we did back in ye olde twentieth century, with a whole separate font file for ligatures. For a language like Arabic that relies heavily on ligatures for correct text composition, that's also a non-good sign.
I understand that there are issues with Arabic fonts in inDesign...I am not able to sue the one I purchased, even when selected, they don't kick in.
So what are you expecting to happen? There are a bunch of things you need to set Arabic type in InDesign; I wouldn't say that there are issues with Arabic fonts in InDesign, but there are certainly issues that you will encounter if you don't know how to handle Arabic text in InDesign.
Is the World-Ready Composer applied to your text? Do you actually have Arabic text flowed into InDesign? (Sorry, I have to ask. It happens far too often that people expect they can select English text, change to Arabic font, and get Arabic text.) Does your font appear at the bottom of the font list with all of the other non-Latin fonts? If you choose your font in the Glyphs menu and mouse over a given Arabic character, does InDesign report the Unicode glyph name correctly?
2. Re: Does anyone know where I can find an .inx file that would bring in the arabic language?
[Jongware] Mar 6, 2012 1:42 PM (in response to iBabs2)How does a font"not kick in"? You have to type in the correct characters, you know.
What version of ziD are you using? Just today I showed proofs to a client, with dozens of Arabic words in the main (English) text and an appendix entirely in Arabic. As it turned out (I always check), she was fluent in Arabic and she commended me with this great looking job. Done with CS4, Peter Kahrel's RTL scripts, and Adobe's own Arabic set of fonts.
3. Re: Does anyone know where I can find an .inx file that would bring in the arabic language?
iBabs2 Mar 6, 2012 2:11 PM (in response to [Jongware])hi guys!
OK-The reason I said InDesign may have problems with Arabic is, I was reading that there is an InDesign ME Version that was created to deal with all middle eastern languages. Sorry, so that is why I assumed that.
I can actually can use the font if I type letters, but since I can't read it or type it, the best I can do is copy and paste the text I receive in an e-mail. If I paste it in text Edit, it works OK..but not InDesign..again, hence why I assumed it was a specific issues. Since we use many foreign languages here, and we have had our struggles with them all, but this one I just can't get to work. If I paste the type in and select it and apply the font, I just get pink, not even any characters, just pink lines.sorry again, that is what I meant by not kicking in ;-)
I did find an article on how to deal with getting other languages in that dropdown, but I couldn't figure out the things to change, when opening the inx file in a text editor..Here is the link to the article, it may be the same one you saw?
I tried to copy and paste into a word document, so I could attempt the place option..But it converts the font to Adobe Arabic in word...Even if I start to type my font in, it seems to recognize it, but then once I tab out of the character field, it kicks back to Adobe Arabic. I still tried to place that file then in InDesign but the adobe Arabic comes in, and when I highlight it and attempt to apply the right font, if goes pink?
Finally, the font doesn't sit at the bottom like many others do, it sits in alphabetical order in the a's..???
thanks....and any other thoughts ;-)
babs
4. Re: Does anyone know where I can find an .inx file that would bring in the arabic language?
Joel Cherney Mar 6, 2012 2:29 PM (in response to iBabs2)the best I can do is copy and paste the text I receive in an e-mail.
Eek. For what it's worth, we have no idea if the text as displayed in your mail client is correct or not.
In InDesign, you need to turn on the World-Ready Composer in order for two things:
1) Right-to-left text flow (not right-align!)
2) Text composition (Arabic is like cursive Latin script, all of the glyphs are supposed to plug into one another)
If the WRC is not on, you're not actually making sense in Arabic.
That is a very bad sign.
It means that probably your Arabic font is ancient and probably isn't actually an Arabic font. If you know anything at all about Arabic, you can try this test: Set some Latin-script text in your bizarro Arabic font. Select one letter. Go to Type -> Glyphs. The one letter you typed will be highlighted. Mouse over it. A mouseover popup should tell you the Unicode name (like LATIN SMALL LETTER B or something like that). Now, click on a single Arabic character. Mouse over. What's its name? I am betting that instead of "ARABIC LETTER HAH WITH HAMZA ABOVE" you'll get something like "LATIN LETTER O WITH DIAERESIS" meaning that your font is probably ancient & unusable. If you could read any Arabic at all, you'd at least be able to look at it and say "Why heck, that's not hah with hamza above!" but if you don't read Arabic you have no way to be sure.
(That's reason 143 out of 3051 "why you shouldn't try to handle Arabic in InDesign if you can't read Arabic")Even if I start to type my font in, it seems to recognize it, but then once I tab out of the character field, it kicks back to Adobe Arabic.
Your font is probably ancient & unusable. Try a different font.
5. Re: Does anyone know where I can find an .inx file that would bring in the arabic language?
EEEEK is right....I need to get that doubled checked!!
I do think this on, but will also double check!! Because we have used other Arabic in the past, I vaguely remember having to deal with the right to left text..
That's what I thought ;-(
I will definitely try that when back in the office tomorrow morning...Intrested to see what comes up.
(That's reason 143 out of 3051 "why you shouldn't try to handle Arabic in InDesign if you can't read Arabic")I know I know...its all Greek to me!!!! I mean Arabic..Sorry, a little bad joke for a tired old lady here ;-)
You are probably right!!!
Will check out those few things in the morning...
Thanks again to both of you!!!
babs
7. Re: Does anyone know where I can find an .inx file that would bring in the arabic language?
Joel Cherney Mar 6, 2012 4:47 PM (in response to Joel Cherney)Here's the link to Language Log explaining the joy of the it's-all-Greek-to-me chart
8. Re: Does anyone know where I can find an .inx file that would bring in the arabic language?
iBabs2 Mar 6, 2012 4:53 PM (in response to Joel Cherney)Oh you made my night!!!!
where do you find this stuff
LOL!!!
9. Re: Does anyone know where I can find an .inx file that would bring in the arabic language?
iBabs2 Mar 7, 2012 6:00 AM (in response to iBabs2)It means that probably your Arabic font is ancient and probably isn't actually an Arabic font. If you know anything at all about Arabic, you can try this test: Set some Latin-script text in your bizarro Arabic font. Select one letter. Go to Type -> Glyphs. The one letter you typed will be highlighted. Mouse over it. A mouseover popup should tell you the Unicode name (like LATIN SMALL LETTER B or something like that). Now, click on a single Arabic character. Mouse over. What's its name? I am betting that instead of "ARABIC LETTER HAH WITH HAMZA ABOVE" you'll get something like "LATIN LETTER O WITH DIAERESIS" meaning that your font is probably ancient & unusable. If you could read any Arabic at all, you'd at least be able to look at it and say "Why heck, that's not hah with hamza above!" but if you don't read Arabic you have no way to be sure.
Yep..its really bad....actually it now turns into a bunch of ??????? and that is the glyph it says it is...just a "?"..
Oh well...sad to say, but I have to work it in quark with the arabic extension..how sad...
thanks for all the help!
babs
10. Re: Does anyone know where I can find an .inx file that would bring in the arabic language?
Joel Cherney Mar 7, 2012 9:32 AM (in response to iBabs2)Ah yes, I used ArabicXT on the regular when I was just starting out. Back in the 90s, it blew my post-collegiate mind to use professional-grade Arabic tools. To be honest, your font sounds like it is from the era of Quark 4 or thereabouts, so it makes sense that you'd want to take it back to Quark. Even if you're using a new version of Quark, I assume that ArabicXT maintains backwards compatibility for ye olde type 1 complex-script Mac fonts.
Oh, yeah. It's a different kind of bad than I thought it was, but it's still not something that is going to work in contemporary software without a gigantic pile of hacks. I have a few Mac T1 fonts for non-English languages that behave in exactly this way, and there's really nothing to do for 'em but to write little converters in Javascript that remap "?" to "ARABIC LETTER HAH WITH HAMZA ABOVE." Which is, to be honest, the only reason I know anything at all about Javascript.
Anyhow, have fun spending the afternoon in Quark, & good luck.
11. Re: Does anyone know where I can find an .inx file that would bring in the arabic language?
iBabs2 Mar 7, 2012 9:53 AM (in response to Joel Cherney)Hello,
I was trying to figure out more about the Word-Ready Composer .... any gudiance to how I might get that going?
The quark thing isn't great. I can paste from word to a text box and some stuff comes in perfect, then some lines, the words gets switched around..not flopped, just out of order??? So, you have to copy and paste the order back line by line. Although the fact that others come in fine, is so add.
So, with that, I am stuill looking for an InDesign solution....if you can tell me where I can find more on this composer that woudl be great!!!
Thanks!
babs
12. Re: Does anyone know where I can find an .inx file that would bring in the arabic language?
Joel Cherney Mar 7, 2012 10:25 AM (in response to iBabs2)There are a wide variety of ways to use the WRC in CS4 or above. If you know how to install a script, then this script creates a paragraph style with the WRC turned on and the text flowing right-to-left. If you're using CS5 or CS5.5 and would rather use a plugin with a nice user interface, try installing the demo for World Tools. (And if you're going to do Arabic on any kind of regular basis, it's worth every penny.)
Mailservers are a pretty poor way to move Arabic text around from translators to formatters. It seems to me, from your description, that your words in the email are right-to-left but either your email client or your clipboard is turning the spaces into left-to-right spaces. It'd be best to move all the text into, say, TextEdit, and a) PDF it and mail it back saying "I can't read Arabic, is this in the correct order?" and b) placing that RTF instead of trying to copy/paste.
13. Re: Does anyone know where I can find an .inx file that would bring in the arabic language?
iBabs2 Mar 7, 2012 11:04 AM (in response to Joel Cherney)There are a wide variety of ways to use the WRC in CS4 or above. If you know how to install a script, then this script creates a paragraph style with the WRC turned on and the text flowing right-to-left. If you're using CS5 or CS5.5 and would rather use a plugin with a nice user interface, try installing the demo for World Tools. (And if you're going to do Arabic on any kind of regular basis, it's worth every penny.)
Great..I will start here...
Actually, they are word docuemnt's...not e-mail anymore... I have tried the place and copy and paste with the word...in quark pretty close, in InDesign nada..but I am going to look at where you have pointed me too..hopefully, I can get this going!!
thanks so much!
babs
14. Re: Does anyone know where I can find an .inx file that would bring in the arabic language?
Willi Adelberger Mar 7, 2012 11:15 AM (in response to iBabs2)You have either the possibility to buy the ME version whichis incompatible to the western version of InDesign or if you need your wester version you can buy one of the world publishing plug ins (e.g. from in-tools.com) which will add ME capabilites to western versions.
Copying arabic text into a western version without such an extension will cause further problems. Some of them you will not see, even MS Word is not fully capable to produce correct ME texts. E.g. numbers are like the western numbers, but Arabs have different numbers, often you will not realize when a left right text is undverible turned over.
15. Re: Does anyone know where I can find an .inx file that would bring in the arabic language?
iBabs2 Mar 7, 2012 1:22 PM (in response to Willi Adelberger)Hello Willi,
I will look into the publishing plug-in....I did load the script mentioned above and it actually did a pretty good job..except that every character is flipped!!! oy... I can't just flip the text box and switch the alignment cause the characters are still facing the wrong direction. Every letter looks correct and in in the right location, it just is flipped?
So weird.....thanks for the extra info!!
I appreciate that.
babs
16. Re: Does anyone know where I can find an .inx file that would bring in the arabic language?
Joel Cherney Mar 7, 2012 1:32 PM (in response to iBabs2)I will look into the publishing plug-in....I did load the script mentioned above and it actually did a pretty good job..except that every character is flipped!!! oy...
Can you post a screenshot? It sounds to me like the WRC is on (the cursive-y bits plug into one another) but the text is flowing left to right. But I can't be sure... you might be using one of those ancient mirror-reversed fonts where the whole point was to lay out left-to-right and then mirror-reverse the frame.
17. Re: Does anyone know where I can find an .inx file that would bring in the arabic language?
Joel Cherney Mar 7, 2012 1:32 PM (in response to Willi Adelberger)Copying arabic text into a western version without such an extension will cause further problems. Some of them you will not see, even MS Word is not fully capable to produce correct ME texts. E.g. numbers are like the western numbers, but Arabs have different numbers, often you will not realize when a left right text is undverible turned over.
Good point, Willi. Although I am in complete agreement with the gist of your post, I disagree a bit with your exact phrasing - it is possible to typeset fully correct Arabic in either InDesign or Word. It might not be beautiful; this is problematic in a language where calligraphic beauty is more generally important than it is in Latin-script languages. But it is possible, with adequate knowledge of how the script works combined with judicious insertion of left-to-right markers, right-to-left markers, manual insertion of Arabic-Indic digits, etc. etc., to set up Arabic correctly, in Word or in InDesign. It's even more complicated when you're doing Arabic, Farsi, and Urdu - not only does Arabic have a numeral system that differs from numerals used in Latin-script languages, but Urdu and Farsi use a numeral system that is similar but not identical to the system used in Arabic.
And, for sure, copying & pasting Arabic into plain-vanilla English InDesign is problematic, depending on the localization of the OS, the clipboard settings, and so on. But, if you are Javascript-savvy, all of the RTL text processing tools that are available in World Tools are accessible to scripting. (At least, I think so... perhaps what I'm saying is only true of the previous version of World Tools for CS4.)
I guess what I'm saying is (italics mine):
Copying arabic text into a western version without such an extension will cause further problems. Some of them you will not see if you are not literate in Arabic, neither MS Word nor InDesign is not fully capable to produce correct ME texts without lots of work from someone who already knows the typesetting conventions of Arabic, and the limitations of the application, and of the OS in which it is installed.
18. Re: Does anyone know where I can find an .inx file that would bring in the arabic language?
iBabs2 Mar 8, 2012 5:43 AM (in response to Joel Cherney)Good News!!
I did demo the in-tools stuff and I was able to get the Arabic style sheet with that script...all helped, but I still had to tweak a few things....!!
So, I decided to take it home and open the word document in my 2010 version on the mac..I copied it in both InDesign and Illustrator, just did a paste (not in any existing text box...that didn't work), but just a paste and it was great in both programs...(Illustrator made it heavier, that was the only thing) but InDesign pasted it perfectly!!!!
So, I guess the 2010 Word is just handling this better????
In Any case!!! thanks for all the help and guidance here!!
babs
