I'd like to get the best results possible when "playing out" a given Premiere sequence through my Kona LHi. I'm particularly
interested in optimizing downconversion (HD-SD) via hardware. If there are differences between "preview" output and "play"
output, I'd like to know what effect that has on a hardware "playout".
Given a sequence that doesn't need rendering, I have the Pr program monitor set for high quality, full res, full speed, and
have the player set to AJA. Clicking the "play" arrow, I'm able to output the sequence from Premiere, and capture the down-
converted video on a second PC. Very good results!
My question / concern is more related to the case when rendering might be necessary, such as when there is a yellow or red
line above the sequence. Under this circumstance, if the sequence is rendered, will the output to the Kona LHi be degraded,
or just as good as a sequence that doesn't need rendering?
So, if a render IS required, might I be better off exporting a DI file, re-importing the DI, then outputing the DI through the hardware? Or, would letting Premiere create the preview (render file?), and outputting the preview through the hardware be just as good?
Comments will be appreciated...Ben
My setup is...
CS5.5
win 7 / 64
i7 3930K
X79 chip set
16 G ram
GTX570
Areca ARC-1213-4I
Kona LHi
drive 1: win 7, apps
drive 2: media, project files (Areca raid 3)
drive 3: media cache, media cache database, win 7 swap
drive 4: preview files
