1. Re: I can't seem to remove the color from the buttons...
John Waller Mar 7, 2012 3:37 PM (in response to John Nez)It's coming from the background: #C6D580; attribute in this rule
ul.nav a, ul.nav a:visited { /* grouping these selectors makes sure that your links retain their button look even after being visited */
padding: 5px 5px 5px 15px;
display: block; /* this gives the link block properties causing it to fill the whole LI containing it. This causes the entire area to react to a mouse click. */
width: 160px; /*this width makes the entire button clickable for IE6. If you don't need to support IE6, it can be removed. Calculate the proper width by subtracting the padding on this link from the width of your sidebar container. */
text-decoration: none;
2. Re: I can't seem to remove the color from the buttons...
John Nez Mar 7, 2012 3:51 PM (in response to John Nez)Thanks so much! Worked first try... after my trying for hours to fill in the little box with the diagonal cross thinking that was the way to mark a color as empty to not display!
I guess I got used to using that box with the diagonal in Adobe Illustrator and figured it'd work in DW too.
Thanks again...
