3 Replies Latest reply on Mar 15, 2012 11:21 PM by Patel Bharat
    PopUpManager issue
    jfb00 Level 3
      I am getting an error in flex sdk 4.6 for PopUpManager, i am trying to center the window, it works in sdk 4.5.1.
      If I use this instead of this.parentDocument as DisplayObject, it works but it doesn't center the window.
      win=My_Screen(PopUpManager.createPopUp(this.parentDocument as DisplayObject, My_Screen, true));
      PopUpManager.centerPopUp(win);
      Any ideas?
      Thanks!
        • 1. Re: PopUpManager issue
          Sathyamoorthi Level 2
          what "this.parentDocument" refres? popup will be centered to "this.parentDocument".
          • 2. Re: PopUpManager issue
            jfb00 Level 3
            Thanks for you help and reply.
            I have an app that will have a controlBarContent at top and a module at the bottom.
            From the module i want to open this popUp screen, it works but it is centring the only in the module not in the whole browser screen.
            With this.parentDocument i point to the main app but looks like it is different in sdk 4.6. i try also this.parentApplication and it works but also centering on the module.
            I hope someone can help.
            Best,
            • 3. Re: PopUpManager issue
              Patel Bharat Level 2
              Hi try below code, which will open center popup window
                                               xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
                        <fx:Declarations>
                                  <!-- Place non-visual elements (e.g., services, value objects) here -->
                        </fx:Declarations>
                        <s:controlBarContent>
                                  <s:Button id="btn"
                                                        label="Show TitleWindow"
                                                        click="btn_click(event);" />
                        </s:controlBarContent>
                        <fx:Script>
                                  <![CDATA[
                                            import MyTitleWindow;
                                            import mx.managers.PopUpManager;
                                            protected function btn_click(evt:MouseEvent):void {
                                                      var ttlWndw:MyTitleWindow = PopUpManager.createPopUp(this, MyTitleWindow, true) as MyTitleWindow;
                                                      PopUpManager.centerPopUp(ttlWndw);
                        </fx:Script>
              </s:Application>
              MyTitleWindow component as below:
              <s:TitleWindow name="MyTitleWindow"
                                               xmlns:mx="library://ns.adobe.com/flex/halo"
                                               title="Spark TitleWindow title"
                                               width="300" height="200"
                                               close="ttlWndw_close(event);">
                        <fx:Script>
                                  <![CDATA[
                                            import mx.core.IFlexDisplayObject;
                                            import mx.events.CloseEvent;
                                            protected function ttlWndw_close(evt:CloseEvent):void {
                                                      PopUpManager.removePopUp(evt.currentTarget as IFlexDisplayObject);
                        </fx:Script>
              </s:TitleWindow>
              Hope this could be helpful.
