1 Reply Latest reply on Mar 8, 2012 2:33 AM by try67
    How to read the header of acrobat using javascript?
    skpoojar
      I have a acrobat file which has been created by using the conversion of various files. I mean to say,for ex, the word file is converted to pdf and attached into it.
      Now, I need to distinguish those files by reading header of each attachments. Is it possible in Javascript?
      Thanks in advance.....
        • 1. Re: How to read the header of acrobat using javascript?
          That could be very tricky. You need to be able to identify the header based
          on some criteria. For example, does it always appear in the same place? If
          so, you can use the quads of the words to locate it. Or if it always
          follows or is preceded by certain text then you can look for that. Or even
          looking at the size of the words is possible (again, using quads). These
          are not trivial tasks, though, and require quite a bit of scripting
          knowledge...
