1. Re: RHCL in RH9 not working
VikramGaurMar 13, 2012 7:08 AM (in response to DannyH.)
Hello DannyH,
Welcome to Adobe Robohelp Forums.
1) Can you generate output using RHCL for a test or a new project in Robohelp 9?
2) You mentioned that you are using a batch file, did you tried only a single command : rhcl [project path] [-l] [layout name]
Complete document : http://help.adobe.com/en_US/robohelp/robohtml/WS5b3ccc516d4fbf351e63e3d11aff59c2a0-7fe3.ht ml
Also if possible upload some screenshots, also you can contact us on tcssup@adobe.com
Vikram
2. Re: RHCL in RH9 not working
DannyH. Mar 13, 2012 7:41 AM (in response to VikramGaur)Hi Vikram,
I cannot generate anything with RHCL. No old project, no new project, not by using bat file and not by command line. It is always the same.
The same bat worked with RH 8. With RH 9 everything is the same, except the installation path of RH and this is already changed in the bat file. In the bat file I call the program with this line:
"C:\Program Files (x86)\Adobe\Adobe RoboHelp 9\RoboHTML\RHCL.exe" "C:\mypath\name-DE.xpj" -o "C:\mypath\onlinehelpdir\de" -l "WebHelp XYZ"
Is it possible that the operating system plays a role? RH 8 was installed on Windows XP and now I have RH 9 on Windows 7 now. RH 9 is installed in the "Program Files (x86)" directory. But that should not be the problem, RHCL is started but it seems that it does not accept the project.
The only WebHelp generation that works is directly from RoboHelp HTML.
My screenshots would be in German. What detail is interesting for you?
Regards
Danny
3. Re: RHCL in RH9 not working
VikramGaurMar 13, 2012 7:59 AM (in response to DannyH.)
Hello,
Is you Operating System is in German or Robohelp 9 is installed in German ?
Any possibility for a Screen Sharing, If yes (Email me : tcssup@adobe.com)
Vikram
4. Re: RHCL in RH9 not working
DannyH. Mar 13, 2012 8:03 AM (in response to VikramGaur)Both German. And sorry, no possibility for screen sharing.
5. Re: RHCL in RH9 not working
RoboColum(n) Mar 13, 2012 8:17 AM (in response to DannyH.)You may not be aware that Vikram is an Adobe employee. It would not be in his or Adobe's interests to compromise your IP.
6. Re: RHCL in RH9 not working
DannyH. Apr 10, 2012 7:07 AM (in response to RoboColum(n))When testing other new functions of RH 9 I got error messages about missing MSXML. So we downloaded and installed it and surprise ... RHCL is working now !!!
So the problem was: MSXML was missing.
It would be great, if an error message could be added to RH which gives a hint that MSXML is missing.
7. Re: RHCL in RH9 not working
Jeff_Coatsworth Apr 10, 2012 7:44 AM (in response to DannyH.)Use the Wish list/Bug Reporting form to bring this to Adobe's attention.
