2 Replies Latest reply on Mar 8, 2012 5:11 AM by natdeamer
    Script - Paste a Group into a TextFrame
      Very similar to my last question here - http://forums.adobe.com/message/4167532
      In Indesign desktop I can copy and paste a group inside a text frame - obviously this can't be done in Indesign server.
      I have tried looking at the duplicate and move methods - but these don't take a page item as the 'to' parameter.
      var textFrame = myPage.pageItems.item("TextFrame");
      var group1 = myPage.pageItems.item("group1");
      var group2 = myPage.pageItems.item("group1");
      I can remove items once they are already in the text frame with
      PageItems is read only - so I can't add items to it.
        • 1. Re: Script - Paste a Group into a TextFrame
          Alas -- the following did not work, although it does with another kind of item (try with "rectangles.add", that works). It may give you some fresh ideas, so I'm showing it anyway:
          textFrame = app.selection[0].parentTextFrames[0];
          group1 = app.layoutWindows[0].activePage.parent.groups[0];
          group1elements = group1.ungroup();
          textFrame.insertionPoints[1].groups.add(group1elements); <-- fail!
          You can test this in the UI version with (1) some group, and (2) a text frame with the text cursor inside it.
          The "fail" line errors out with
          JavaScript Error!
          Error Number: 24
          Error String: textFrame.insertionPoints[1].groups.add is not a function
          File: zzztry.js
          Line: 5
          Source: textFrame.insertionPoints[1].groups.add(group1elements);
          which is kind of a bummer.
          • 2. Re: Script - Paste a Group into a TextFrame
            natdeamer Level 1
            Hi Jongware
            I tried with textFrame.insertionPoints[0].groups.add(...) - but obviously like you found doesn't work.  Will look into rectangles.
