10 Replies Latest reply on Mar 9, 2012 8:36 AM by HectorresDesign
    How do I scale square frames in CS5 using applescript?
    HectorresDesign Level 1
      I need help fixing a script which changes the scale of square frames after it duplicates them. The script worked fine in CS1 but not for CS5. I tried changing "resize" to "scale" but it doesn't compile correctly. Does anyone know how to change "resize mySelection01 horizontal scale 21.6 vertical scale 21.6" to work for CS5?
      Hector
      tell application "Adobe InDesign CS5.5"
          set myDocument to active document
          tell myDocument
              set startinglayer to "Image"
              tell page 2 of myDocument
                  set mySelection01 to rectangle 1
                  duplicate mySelection01
                  move mySelection01 to page 28 of myDocument
                  move mySelection01 to {15, 55}
                  set properties of mySelection01 to {fill color:swatch "None" of myDocument, stroke color:swatch "Black" of myDocument, stroke type:stroke style "Solid" of myDocument, stroke weight:0.25}
              end tell
              tell page 4 of myDocument
                  set mySelection02 to rectangle 1
                  duplicate mySelection02
                  resize mySelection02 horizontal scale 21.6 vertical scale 21.6
                  move mySelection02 to page 28 of myDocument
                  move mySelection02 to {116, 55}
                  set properties of mySelection02 to {fill color:swatch "None" of myDocument, stroke color:swatch "Black" of myDocument, stroke type:stroke style "Solid" of myDocument, stroke weight:0.25}
              end tell
              tell page 6 of myDocument
                  set mySelection03 to rectangle 1
                  duplicate mySelection03
                  resize mySelection03 horizontal scale 21.6 vertical scale 21.6
                  move mySelection03 to page 28 of myDocument
                  move mySelection03 to {218, 55}
                  set properties of mySelection03 to {fill color:swatch "None" of myDocument, stroke color:swatch "Black" of myDocument, stroke type:stroke style "Solid" of myDocument, stroke weight:0.25}
              end tell
              tell page 8 of myDocument
                  set mySelection04 to rectangle 1
                  duplicate mySelection04
                  resize mySelection04 horizontal scale 21.6 vertical scale 21.6
                  move mySelection04 to page 28 of myDocument
                  move mySelection04 to {319, 55}
                  set properties of mySelection04 to {fill color:swatch "None" of myDocument, stroke color:swatch "Black" of myDocument, stroke type:stroke style "Solid" of myDocument, stroke weight:0.25}
              end tell
              tell page 10 of myDocument
                  set mySelection05 to rectangle 1
                  duplicate mySelection05
                  resize mySelection05 horizontal scale 21.6 vertical scale 21.6
                  move mySelection05 to page 28 of myDocument
                  move mySelection05 to {15, 157}
                  set properties of mySelection05 to {fill color:swatch "None" of myDocument, stroke color:swatch "Black" of myDocument, stroke type:stroke style "Solid" of myDocument, stroke weight:0.25}
              end tell
              tell page 12 of myDocument
                  set mySelection06 to rectangle 1
                  duplicate mySelection06
                  resize mySelection06 horizontal scale 21.6 vertical scale 21.6
                  move mySelection06 to page 28 of myDocument
                  move mySelection06 to {116, 157}
                  set properties of mySelection06 to {fill color:swatch "None" of myDocument, stroke color:swatch "Black" of myDocument, stroke type:stroke style "Solid" of myDocument, stroke weight:0.25}
              end tell
              tell page 14 of myDocument
                  set mySelection07 to rectangle 1
                  duplicate mySelection07
                  resize mySelection07 horizontal scale 21.6 vertical scale 21.6
                  move mySelection07 to page 28 of myDocument
                  move mySelection07 to {218, 157}
                  set properties of mySelection07 to {fill color:swatch "None" of myDocument, stroke color:swatch "Black" of myDocument, stroke type:stroke style "Solid" of myDocument, stroke weight:0.25}
              end tell
              tell page 16 of myDocument
                  set mySelection08 to rectangle 1
                  duplicate mySelection08
                  resize mySelection08 horizontal scale 21.6 vertical scale 21.6
                  move mySelection08 to page 28 of myDocument
                  move mySelection08 to {319, 157}
                  set properties of mySelection08 to {fill color:swatch "None" of myDocument, stroke color:swatch "Black" of myDocument, stroke type:stroke style "Solid" of myDocument, stroke weight:0.25}
              end tell
              tell page 18 of myDocument
                  set mySelection09 to rectangle 1
                  duplicate mySelection09
                  resize mySelection09 horizontal scale 21.6 vertical scale 21.6
                  move mySelection09 to page 28 of myDocument
                  move mySelection09 to {15, 258}
                  set properties of mySelection09 to {fill color:swatch "None" of myDocument, stroke color:swatch "Black" of myDocument, stroke type:stroke style "Solid" of myDocument, stroke weight:0.25}
              end tell
              tell page 20 of myDocument
                  set mySelection10 to rectangle 1
                  duplicate mySelection10
                  resize mySelection10 horizontal scale 21.6 vertical scale 21.6
                  move mySelection10 to page 28 of myDocument
                  move mySelection10 to {116, 258}
                  set properties of mySelection10 to {fill color:swatch "None" of myDocument, stroke color:swatch "Black" of myDocument, stroke type:stroke style "Solid" of myDocument, stroke weight:0.25}
              end tell
              tell page 22 of myDocument
                  set mySelection11 to rectangle 1
                  duplicate mySelection11
                  resize mySelection11 horizontal scale 21.6 vertical scale 21.6
                  move mySelection11 to page 28 of myDocument
                  move mySelection11 to {218, 258}
                  set properties of mySelection11 to {fill color:swatch "None" of myDocument, stroke color:swatch "Black" of myDocument, stroke type:stroke style "Solid" of myDocument, stroke weight:0.25}
              end tell
              tell page 24 of myDocument
                  set mySelection12 to rectangle 1
                  duplicate mySelection12
                  resize mySelection12 horizontal scale 21.6 vertical scale 21.6
                  move mySelection12 to page 28 of myDocument
                  move mySelection12 to {319, 258}
                  set properties of mySelection12 to {fill color:swatch "None" of myDocument, stroke color:swatch "Black" of myDocument, stroke type:stroke style "Solid" of myDocument, stroke weight:0.25}
              end tell
          end tell
      end tell
        • 1. Re: How do I scale square frames in CS5 using applescript?
          Muppet Mark Level 5
          Hector… I will take a look at the new syntax for resizing in CS5… While I do, consider using a loop for operations like this… There is no need to repeat syntax like you have done… Have the syntax repeat itself… You probably only need some variables for positions x, y and an incrementor…
          tell application "Adobe InDesign CS5"
                    tell the active document
                              repeat with i from 2 to 24 by 2
                                        tell page i
            -- do stuff here
                                        end tell
            display alert i giving up after 1
                              end repeat
                    end tell
          end tell
          • 2. Re: How do I scale square frames in CS5 using applescript?
            Thanks for the tip, the script would be a lot simpler with a single repeating line. I'll try to implement the change you suggested and thanks for looking into the syntax.
            Hector
            • 3. Re: How do I scale square frames in CS5 using applescript?
              Kevin Parrott Level 2
              hI Hector
              using geometric bounds will set your rectangle size
                  tell myDocument
                          set geometric bounds of mySelection01 to {0, 0, 21.6, 21.6}
                      end tell
                  end tell
              end tell
              • 4. Re: How do I scale square frames in CS5 using applescript?
                I'm going to try your script now and see if it works, thank you!
                • 5. Re: How do I scale square frames in CS5 using applescript?
                  Hi Kevin,
                  I just ran the script and its making the correct size frame which is great. The only thing missing is the images are not being scaled with the frame and are left at their original size. Do you know what code I can add to make the images scale along with the frame?
                  Thank you so much,
                  Hector
                  • 6. Re: How do I scale square frames in CS5 using applescript?
                    my appologies, please try this
                        tell myDocument
                                set properties of item 1 of mySelection01 to {horizontal scale:21.6, vertical scale:21.6}
                                --set geometric bounds of mySelection01 to {0, 0, 21.6, 21.6}
                                fit rectangle 1 given center content
                            end tell
                        end tell
                    end tell
                    • 7. Re: How do I scale square frames in CS5 using applescript?
                      you rock! that code worked. I just added this line to my code "set properties of item 1 of mySelection01 to {horizontal scale:21.6, vertical scale:21.6}" and it worked. Now if I could make a loop instead of repeating the code like Mark said the scripts would be perfect. But I'm extremely happy this works, saves so much time
                      Thank you,
                      Hector
                      • 8. Re: How do I scale square frames in CS5 using applescript?
                        great, glad that worked,  i agree with mark, it will shorten your code (less code is good), and
                        maybe speed up the operation
                        kp
                        • 9. Re: How do I scale square frames in CS5 using applescript?
                          Muppet Mark Level 5
                          Hector, I would have gone the route of transforming the rectangle myself… but matrix is a little tricky to get the lingo right… Only done it in ExtendScript before now… Any how this should give you the general idea of the loop… Your X&Y values are not equidistant so I went for a list instead…
                                              set dupPage to page 28
                            -- Loop the 12 items
                                              repeat with i from 1 to 12
                            -- A list of 12 X&Y pair lists
                                                        set posBox to {{15, 55}, {116, 55}, {218, 55}, {319, 55}, ¬
        {15, 157}, {116, 157}, {218, 157}, {319, 157}, ¬
        {15, 258}, {116, 258}, {218, 258}, {319, 258}}
                            -- Double the value of i for the page ref
                                                        tell page (i * 2)
        set dupeBox to duplicate rectangle 1
                            -- Transform the matrix here
        -- or use your property value change…
                            move dupeBox to dupPage
                            move dupeBox to item i of posBox
        set fill color of dupeBox to "None"
        set stroke color of dupeBox to "Black"
        set stroke type of dupeBox to "Solid"
        set stroke weight of dupeBox to 0.25
                                                        end tell
                                              end repeat
                                    end tell
                          end tell
                          • 10. Re: How do I scale square frames in CS5 using applescript?
                            Mark, your code works perfectly. I used your code and added the scale line.The code now works and is a lot simpler:
                                        set posBox to {{14.4, 57.875}, {134.875, 57.875}, {255.875, 57.875}, {375.875, 57.875}, ¬
                                            {14.4, 177.875}, {134.875, 177.875}, {255.875, 177.875}, {375.875, 177.875}, ¬
                                            {14.4, 297.875}, {134.875, 297.875}, {255.875, 297.875}, {375.875, 297.875}}
                                        tell page (i * 2)
                                            set properties of item 1 of dupeBox to {horizontal scale:21.6, vertical scale:21.6}
                                        end tell
                                    end repeat
                                end tell
                            end tell
