7 Replies Latest reply on Aug 9, 2006 3:05 PM by seth_hodgson
    Getting access to Soap Faults
    rmarp
      Folks,
      I am using the WebService object in Flex/AS3. The documentation states the following:
      quote:
      NOTE: You must use the Flex proxy, which is part of Flex Data Services, to ensure that HTTP status codes are returned correctly from HTTP services and web services. On web browsers, when a service returns any status code other than 200, Adobe Flash Player cannot read the body of the response. If the status code is 500 and the body contains a fault, there is no way to get to the fault. The proxy works around this issue by forcing the status code for faults to 200; the player passes the body of the response along with the fault intact.
      Ok so this makes sense in principle. But the documentation is very weak in explaining what exactly the proxy mechanism is and how to configure it. Does anybody have any ideas?
      Without this, any soap fault that occurs during a web service call (which is very valid behavior) will never get properly handled by Flash and thus just returns a generic "HTTP request error".
        • 1. Re: Getting access to Soap Faults
          aglosband
          To make your web service request go through the proxy, you set the useProxy property of your web service to true, so
          myService.useProxy = true;
          If you set the wsdl property on the web service rather than specifying a destination, the destination DefaultHTTP that is defined in the proxy-config.xml file gets used. The destination has <dynamic-url> properties which contain url patterns that determine which urls the proxy lets through.
          <destination id="DefaultHTTP">
          <properties>
          <dynamic-url> http://myserver.com/myservice/*</dynamic-url><dynamic-url>*</dynamic-url>
          </properties>
          </destination>
          So, to wrap up. To use the proxy, set useProxy to true on your web service. Then edit the DefaultHTTP destination in proxy-config.xml and add a dynamic-url property that will allow your web service request to go through.
          If you want to configure a destination on the server rather than using the wsdl property, look at the Configuring RPC Services -> Configuring destination properties -> Web service properties section in the developers guide. The doc on this is pretty good.
          • 2. Re: Getting access to Soap Faults
            rmarp Level 1
            Thanks for the information Alex. The only thing that's still a bit foggy for me is where I am supposed to place this proxy-config.xml file? Do I just put it in the same folder on my web server as the SWF file for my flex application? I've seen people mention putting it in WEB-INF/flex but that seems to be a Java-specific folder. What if the site that hosts my SWF is ASP.NET or something?
            Ryan
            • 3. Re: Getting access to Soap Faults
              aglosband Level 1
              Ok. I think I see what the confusion is. The WEB-INF/flex directory is a Java-specific folder. It's part of Flex Data Services, which is a j2ee web application. If you're not running the web application then you can't use the proxy.
              • 4. Re: Getting access to Soap Faults
                rmarp Level 1
                Alex - thank you for clarifying this with me. I was confused over this point. I have seen reference to Flex Data Services and now I understand this part. I guess I'm just left with this question then ...
                If I'm not using Data Services, do I not have any way of handing soap faults other than recieving an HTTP request error? If this is the case, this would be quite disappointing as this seems to kill the whole web services scenario.
                • 5. Re: Getting access to Soap Faults
                  seth_hodgson Level 1
                  This issue is a limitation of the plugin API provided by the browser.
                  Using FDS to proxy web service calls allows us to make the proxied call on your behalf from the server where this limitation doesn't exist. A 500 fault response can be returned as a 200 reponse that is readable by Flash.
                  If using FDS to proxy web service calls isn't an option and you need access to the information in SOAP faults, you'd need to do custom work on the server to reset the status code to 200 for the fault responses returned to Flash clients.
                  Best,
                  Seth
                  • 6. Re: Getting access to Soap Faults
                    rmarp Level 1
                    Seth - this is interesting info. So you are saying that when Flash makes external communication via the mx.rpc.http/soap objects that is uses an API on the web browser? Does the same apply to the flash.net objects?
                    • 7. Re: Getting access to Soap Faults
                      The plugin player (non-IE) uses the browser plugin API to make its network calls. The IE player uses the Windows network stack to make its calls. This is true of the flash.net classes, as well as the mx.rpc classes (whose functionality is built on top of flash.net).
                      Best,
                      Seth
