1 Reply Latest reply on Mar 9, 2012 10:14 AM by John Hawkinson
    Keyboard Shortcuts for Object Opacity?
    Andymc7 Level 1
      It seems like there are an array of options in the keyboard shortcuts panel in ID CS5, but I can't seem to figure out how to set keyboard shortcuts for object opacity levels as I have in Illy and PS (1=10%, 2=20$, etc). This would really come in handy for me. Anyone know if this is possible in ID?
        • 1. Re: Keyboard Shortcuts for Object Opacity?
          John Hawkinson Level 5
          You can set Panel Menus > Effects: Transparency and then hitting the keystroke will pop up a dialog box and you can type the number and hit return. This is not what you asked for, but it is not too-too far away.
          You can also do it with a one-line script:
          app.selection[0].transparencySettings.blendingSettings.opacity=50;
          Save as trans50.jsx in your scripts folder and then bind it to a key under Scripting (in Keyboard Shortcuts). Make as many as you like for whatever numbers you like.
