9 Replies Latest reply on Mar 13, 2012 2:05 PM by Zolotoj
    Doc question
    Zolotoj Level 3
      From http://help.adobe.com/en_US/flex/using/WS2db454920e96a9e51e63e3d11c0bf61c8a-7ff9.html:
      You should declare an instance variable for each dynamically created component and store a reference to the newly created component in it, just as the MXML compiler does when you set an id property for a component instance tag. You can then access your dynamically created components in the same way as those declaratively created in MXML.
      Do you think it’s like this:
      var btn:Button = new Button();
      btn.id = "button";
      addElement(btn);
      if yes, then why this does not work?
      this[btn.id]
        • 1. Re: Doc question
          GordonSmith Level 4
          No. You declared a local variable (inside a function) not an instance variable (inside a class).
          If you want your component to have a dynamically created Button, declare
          public var button1:Button;
          in the class and then inside some class method do
          button1 = new Button();
          button1.label = "Whatever";
          addElement(button1);
          You then simply access the button as 'button1'. If you need to make multiple dynamic components, store them in some kind of Array or Object-used-as-a-map. For example,
          public var myDynamicallyCreatedComponents:Object = {};
          and inside some class method do
          var button:Button = new Button;
          button.label = "Whatever";
          addElement(button);
          myDynamicallyCreatedComponents["WhateverButton"] = button;
          You then can access this particular button as myDynamicallyCreatedComponents["WhateverButton"].
          Gordon Smith, Adobe
          • 2. Re: Doc question
            Zolotoj Level 3
            What if I cannot do public?
            • 3. Re: Doc question
              J Clow Level 1
              Then declare a private variable outside of the function, but inside the class.
              • 4. Re: Doc question
                Zolotoj Level 3
                Yes, that's what I have done. Still does not work.
                • 5. Re: Doc question
                  Zolotoj Level 3
                  Here is code:
                                 xmlns:mx="library://ns.adobe.com/flex/mx"
                                 creationComplete="init()"
                      <fx:Script>
                          <![CDATA[
                              import mx.collections.ArrayCollection;
                              import mx.controls.Alert;
                              import mx.events.ListEvent;
                              import flash.display.DisplayObject;
                              import flash.display.DisplayObjectContainer;
                              import spark.components.Button;
                              private var btn1:Button;
                              private function init():void
                                  btn1 = new Button();
                                  btn1.id = "btn";
                                  gr1.addElement(btn1);
                                  trace(gr1[btn1.id]);
                      </fx:Script>
                      <fx:Declarations>
                          <!-- Define model for the credit card data. -->
                      </fx:Declarations>
                      <s:VGroup id="gr1">
                      </s:VGroup>
                  </s:Application>
                  • 6. Re: Doc question
                    J Clow Level 1
                    I don't get why you can't just trace btn1.id for whatever you're trying to do.
                    • 7. Re: Doc question
                      Zolotoj Level 3
                      What I am showing is that:
                      is crashing.
                      • 8. Re: Doc question
                        J Clow Level 1
                        It's crashing because that is not the way to access such an object. What you're trying to do is instead done with the code below
                        var blah:Button= gr1.getElementAt(0) as Button
                        trace(blah.id)
                        However, if you do not want to do that, just trace btn1.id .I do not see the sense in doing whatever you are trying to do currently. and besides, a Vgroup is not an associative array.
                        • 9. Re: Doc question
                          Zolotoj Level 3
                          What I am trying to do in reality is to have a function that would be able to access an object using the following code:
                          view[objectid]. It works with design time controls, but not with these added at run time.
