1 Reply Latest reply on Mar 10, 2012 4:47 PM by gkaiseril
    Code to Automatically Figure and Report Page #? [easy]
    stealthrs Level 1
      Hi, I've made a 100 page PDF that will have changes/updates made every now and then to the order...  Not all 100 pages are needed at all times, so I've made a checkbox that reports to another text field and keeps of what pages are needed when the box is checked yes...
      The working code is below, but is there a way I can code it so it knows what page number it's on automatically?.... Without me having to use manual code as seen below in the Red Text?  I re-organize the pages from time to them, which means I have to manually go back through and update the code.  Can I fix this?
      Thanks!  See the code below!
      // script start
      //get the button
      var btn = this.getField("13_travel");
      //app.alert("value = "+btn.value);
      // this variable would change for each check box to the pages you want printed.
      var pagesToPrint = "92";
      //check value of checkbox
      if(btn.value=="Yes") {
          var action = "add";
      else
          var action = "";
      updatePagesToPrint(pagesToPrint, action);
      function updatePagesToPrint(pagesToPrint, action) {
          //app.alert(pagesToPrint + " :: " + action);
          // get the text field
          var printField = this.getField("pagesToPrint");
          if(action=="add")
              // check if the field is empty
              if ( printField.value == "" || printField.value == " ")
                   printField.value = pagesToPrint;
              else
                   // as printField has a value, add the new pages to the end of the value
                   printField.value = printField.value + ", " + pagesToPrint;
          else
              printField.value = printField.value.replace(pagesToPrint+", ", "");
              printField.value = printField.value.replace(pagesToPrint, "");
              printField.value = printField.value.replace(/^,|^, |, $|,$/, "");
      // script end
        • 1. Re: Code to Automatically Figure and Report Page #? [easy]
          When on a page, the doc object "pageNum" reports the page number of that page. So for a field on any page:
          var pagesToPrint = this.pageNum;
          will report the number of the page.
          If you are dealing with numbers, it is better not to put them in quotation marks unless you want a text string of numbers.
          For the total number of pages in a document you can use the "this.numPages" property.
