3 Replies Latest reply on Jan 25, 2015 6:41 AM by LukeStanyer
    opacity problem
    inquestflash Level 1
      hello forum.
      im lowering the opacity of one layer which has an object,and its affecting all the other layers as well.also the text goes dimmer.
      why is it doing this?
        • 1. Re: opacity problem
          First off, opacity is an object-level attribute, so you can't be changing the opacity of a layer, so let's presume you meant you are lowering the opacity of a single object that is the only thing on a layer on that page.
          Adding transparency to a page can, indeed affect the appearance of every other object on the page. Does switching the transparency blend space (Edit > Transparency Blend Space...) make a difference?
          As rar as the text, best practice is to keep it above all transparency to minimize interaction that can cause it to be outlined or rasterized. Normally we here that it gets darker, rather than lighter, though. What do you have for Appearance of Black in your Prefs?
          • 2. Re: opacity problem
            Hello peter.
            i went to Edit > Transparency Blend Space,and when i changed the colour mode to rgb it worked out as i wanted to.in cmyk mode it all had a different opacity appearance.
            thank you.
            • 3. Re: opacity problem
              LukeStanyer
              Sorted, Thanks!
