0 Replies Latest reply on Mar 11, 2012 9:11 AM by St3ph3n31
    can't connect php reg form to database ??
    St3ph3n31
      Hi guys hope you can help ?? for some reason I can't get this to register details to the database, all the checks work .. password, to long etc , no syntax errors either?
      I'm using wamp 2.2
      many thanks in advance for taking the time
      <?php
      error_reporting (E_ALL ^ E_NOTICE);
      $submit = strip_tags ($_POST['submit']);
      $fullname = strip_tags ($_POST['fullname']);
      $username =strip_tags ($_POST['username']);
      $password =strip_tags($_POST['password']);
      $repeatpassword =strip_tags($_POST ['repeatpassword']);
      $date = date("D-M-Y");
      if ($submit)
         //check for exsitance
         if ($fullname&&$username&&$password&&$repeatpassword)
         if ($password==$repeatpassword)
           // check charcacter length of username and fullname
      if  (strlen($username)>25||strlen($fullname)>25)
           echo  "length of username or full name is too long!";
        else
          // check password length
          if (strlen($password)>25||strlen($password)<6)
          echo "Password must be between 6 and 25 characters!";
          else
            // register the user database
            // encrypt password
            $password = md5($password);
            $repeatpassword = md5($repeatpassword);
            // open our database
            $connect = mysql_connect("localhost","root","");
            mysql_select_db("users"); //selects database
            $queryreg =mysql_query
                                                   (" INSERT INTO users1 VALUES  ('','$fullname','$username','$password','$date',) ");
            die ("You are now registered with Simply priceless ... Welcome! Click here <a href='Home.php'> to return to Home page</a> ");
         else
             echo "Your passwords do not match";
        else
            echo "Please fill in <b>all</b> fields marked with * ";
