3 Replies Latest reply on Mar 11, 2012 10:38 PM by John Hawkinson
    Indesign Crashes with Strange Error Code?
    writer_in_blueridge
      What does this error code mean. It seems to have been the culbrit in many of my Indesign crashes??
      Error Code 0x2c0a: "Object is locked."
      That is what the Protective Shutdown Log shows.
      The log calls it an "Unhandled error condition."
      Yes, I have had locked objects in many book documents. The problem has persisted after exporting all files through idml. Am removing all locked ojects, but I didn't know they could cause problems.
      What is this error code -- and how does one avoid it?
      Thank you.
        • 1. Re: Indesign Crashes with Strange Error Code?
          John Hawkinson Level 5
          We're (still) not sure.
          How does this differ from the question you asked in Re: Why is Indesign Crashing under OSX LION?
          Did the problem come back?
          • 2. Re: Indesign Crashes with Strange Error Code?
            writer_in_blueridge Level 1
            Yes the problem came back.
            After unstalling and re-installing.
            After removing pref folders, etc.
            After exporting to INDL and bringing back to InDesign cs5.5
            After wiping hard drive and rebuilding.
            After font-checking.
            Again, that same locked-object error code appeared -- Error Code 0x2c0a. Object is locked.
            So I thought, why ignore that code. It's trying to tell me something.
            All I could think of was this: On the first page of each chapter, I locked the main test frame and title.
            Each chapter begins on a right-hand page.
            Yet when I would work on prceeding chapters, Indesign would sometimes add pages, causing following chapters to begin on a left-hand page. All main elements on my chapter opening page would shift. This caused extra work to re-align them.
            So I locked them down.
            Maybe the program doesn't like that. But I've worked with Indesign for years and this never happened.
            I just unlocked the elements on those opening pages, and grouped them instead.
            And so far, we are okay.
            Was just trying to make good use of the ProtectiveShutdown Log -- to insure a permanent solution.
            Writing itself can be stressful enough -- for anyone. Ongoing crashes just crank that stress up a much higher level.
            Just wondered if there was some rule of element locking I violated.
            Am grateful to understand all this.
            • 3. Re: Indesign Crashes with Strange Error Code?
              You're definitely seeing a bug. InDesign should never crash under
              normal operation.
              So it's not that you've "violated a rule."
              Something is wrong, and we need to figure out why and how, and what
              you can do to avoid the problem.
