7 Replies Latest reply on Mar 12, 2012 5:47 PM by duhwellhuh
    Problem with IllustratorSaveOptions not saving on Mac but work perfectly on Windows [extendscript]
    duhwellhuh Level 1
      Hey everyone- I am currently running Illustrator CS5 on Windows 7 using extendscript. My issue is this:
      When testing this script on any Windows machine, my script runs as it should but when I try to run it on a Mac using Illustrator CS4, the PDFs save as they should, but the Illustrator file doesn't. The folder contains the PDFs but no Illustrator. I'm currently using CS5 and the IllustratorSaveOptions specify to save as a CS4 file. Any help would be appreciated. I've seen other posts showing IllustratorSaveOptions that  had  "+ 'ai'" and "+ '.pdf'" at the end of the file string. Could that have anything to do with it? The most important part of the script is towards the bottom. Here is my script:
      #target illustrator
      var myDoc = activeDocument;
      var dateFormat = function () {
      var token = /d{1,4}|m{1,4}|yy(?:yy)?|([HhMsTt])\1?|[LloSZ]|"[^"]*"|'[^']*'/g,
        timezone = /\b(?:[PMCEA][SDP]T|(?:Pacific|Mountain|Central|Eastern|Atlantic) (?:Standard|Daylight|Prevailing) Time|(?:GMT|UTC)(?:[-+]\d{4})?)\b/g,
        timezoneClip = /[^-+\dA-Z]/g,
        pad = function (val, len) {
         val = String(val);
         len = len || 2;
         while (val.length < len) val = "0" + val;
         return val;
      // Regexes and supporting functions are cached through closure
      return function (date, mask, utc) {
        var dF = dateFormat;
        // You can't provide utc if you skip other args (use the "UTC:" mask prefix)
        if (arguments.length == 1 && Object.prototype.toString.call(date) == "[object String]" && !/\d/.test(date)) {
         mask = date;
         date = undefined;
        // Passing date through Date applies Date.parse, if necessary
        date = date ? new Date(date) : new Date;
        if (isNaN(date)) throw SyntaxError("invalid date");
        mask = String(dF.masks[mask] || mask || dF.masks["default"]);
        // Allow setting the utc argument via the mask
        if (mask.slice(0, 4) == "UTC:") {
         mask = mask.slice(4);
         utc = true;
        var _ = utc ? "getUTC" : "get",
         d = date[_ + "Date"](),
         D = date[_ + "Day"](),
         m = date[_ + "Month"](),
         y = date[_ + "FullYear"](),
         H = date[_ + "Hours"](),
         M = date[_ + "Minutes"](),
         s = date[_ + "Seconds"](),
         L = date[_ + "Milliseconds"](),
         o = utc ? 0 : date.getTimezoneOffset(),
         flags = {
          d:    d,
          dd:   pad(d),
          ddd:  dF.i18n.dayNames[D],
          dddd: dF.i18n.dayNames[D + 7],
          m:    m + 1,
          mm:   pad(m + 1),
          mmm:  dF.i18n.monthNames[m],
          mmmm: dF.i18n.monthNames[m + 12],
          yy:   String(y).slice(2),
          yyyy: y,
          h:    H % 12 || 12,
          hh:   pad(H % 12 || 12),
          H:    H,
          HH:   pad(H),
          M:    M,
          MM:   pad(M),
          s:    s,
          ss:   pad(s),
          l:    pad(L, 3),
          L:    pad(L > 99 ? Math.round(L / 10) : L),
          t:    H < 12 ? "a"  : "p",
          tt:   H < 12 ? "am" : "pm",
          T:    H < 12 ? "A"  : "P",
          TT:   H < 12 ? "AM" : "PM",
          Z:    utc ? "UTC" : (String(date).match(timezone) || [""]).pop().replace(timezoneClip, ""),
          o:    (o > 0 ? "-" : "+") + pad(Math.floor(Math.abs(o) / 60) * 100 + Math.abs(o) % 60, 4),
          S:    ["th", "st", "nd", "rd"][d % 10 > 3 ? 0 : (d % 100 - d % 10 != 10) * d % 10]
        return mask.replace(token, function ($0) {
         return $0 in flags ? flags[$0] : $0.slice(1, $0.length - 1);
      // Some common format strings
      dateFormat.masks = {
      "default":      "ddd mmm dd yyyy HH:MM:ss",
      shortDate:      "m/d/yy",
      mediumDate:     "mmm d, yyyy",
      longDate:       "mmmm d, yyyy",
      fullDate:       "dddd, mmmm d, yyyy",
      shortTime:      "h:MM TT",
      mediumTime:     "h:MM:ss TT",
      longTime:       "h:MM:ss TT Z",
      isoDate:        "yyyy-mm-dd",
      isoTime:        "HH:MM:ss",
      isoDateTime:    "yyyy-mm-dd'T'HH:MM:ss",
      isoUtcDateTime: "UTC:yyyy-mm-dd'T'HH:MM:ss'Z'"
      // Internationalization strings
      dateFormat.i18n = {
      dayNames: [
        "Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat",
        "Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"
      monthNames: [
        "Jan", "Feb", "Mar", "Apr", "May", "Jun", "Jul", "Aug", "Sep", "Oct", "Nov", "Dec",
        "January", "February", "March", "April", "May", "June", "July", "August", "September", "October", "November", "December"
      // For convenience...
      Date.prototype.format = function (mask, utc) {
      return dateFormat(this, mask, utc);
      var now = new Date();
      var now_format = now.format("mmddyy");
      /*with (myDoc) {
           for (var i = textFrames.length-1; i >= 0; i--) {
                textFrames[i].createOutline();
           alert('Done…');
      function outlineDocText(  ) {
                if ( app.documents.length == 0 ) return;
                recurseLayers( myDoc.layers );
      outlineDocText();
      function recurseLayers( objArray ) {
                for ( var i = 0; i < objArray.length; i++ ) {
                          // Record previous value with conditional change
                          var l = objArray[i].locked;
                          if ( l ) objArray[i].locked = false;
                          var v = objArray[i].visible;
                          if ( !v ) objArray[i].visible = true;
                          outlineText( objArray[i].textFrames );
                          // Recurse the contained layer collection
                          if ( objArray[i].layers.length > 0 ) {
                                    recurseLayers( objArray[i].layers )
                          // Recurse the contained group collection
                          if ( objArray[i].groupItems.length > 0 ) {
                                    recurseGroups( objArray[i].groupItems )
                          // Return to previous values
                          objArray[i].locked = l;
                          objArray[i].visible = v;
      function recurseGroups( objArray ) {
                          var h = objArray[i].hidden;
                          if ( h ) objArray[i].hidden = false;
                          objArray[i].hidden = h;
      function outlineText( objArray ) {
                // Reverse this loop as it brakes the indexing
                for ( var i = objArray.length-1; i >= 0; i-- ) {
                          var g = objArray[i].createOutline(  );
                          // Return new group to previous Text Frame values
                          g.locked = l;
                          g.hidden = h;
      var myPermission =confirm ("Are you sure you're ready to save?","","Save Script Execution")
      if (myPermission){
      var myFileName = prompt ("Enter Filename","");
      if (myFileName){
      var destFolder = Folder.selectDialog('Select which folder to save to Katie:');
      else
      alert ("Save cancelled");
      if (destFolder) {
      /*Save as Illustrator CS4*/
      var IFile = new File(destFolder + '/' + myFileName);
      var ISave = new IllustratorSaveOptions();
          with (ISave){
              compatibility = Compatibility.ILLUSTRATOR14;
         /*Save as standard PDF*/
          var IPreset = '[Illustrator Default]'
          var pdfSave = new PDFSaveOptions();
          var pdfFile = new File(destFolder + '/' + myFileName);
              with (pdfSave){
                   pDFPreset = IPreset;
                   viewAfterSaving = false;
                   compatibility = PDFCompatibility.ACROBAT5;
      /*Save as smallest PDF*/
      var SmallestPDF = '[Smallest File Size]';
      var pdfSaveOpts = new PDFSaveOptions();
      var pdfFileCompressed = new File(destFolder + '/' + myFileName +'%2e' + now_format);
          with (pdfSaveOpts){
              pDFPreset = SmallestPDF;
      destFolder.execute()
      myDoc.saveAs (IFile, ISave)
      myDoc.saveAs(pdfFile, pdfSave)
      myDoc.saveAs(pdfFileCompressed, pdfSaveOpts)
      else {
      alert("Save cancelled!")
        • 1. Re: Problem with IllustratorSaveOptions not saving on Mac but work perfectly on Windows [extendscript]
          Muppet Mark Level 5
          Ignore the file suffix/extension you see in some other scripts… Its a cheat… An *.ai file is based closely on the *.pdf so im some cases its indended to fool the OS or other apps/devices such as ipad… You should suffix your file correctly if this is NOT your intent…
          • 2. Re: Problem with IllustratorSaveOptions not saving on Mac but work perfectly on Windows [extendscript]
            duhwellhuh Level 1
            But could this keep the AI file from showing up on a MAC system if they weren't suffixed in the script? I'm not trying to cheat or confuse the system. I want to save an AI as an AI and a PDF as a PDF. My intent is to get it to work and keep it functional and that was just an idea of why it might not be working.
            I'm trying to figure out why this script would work perfectly in Windows with all saved files appearing correctly in the chosen folder, but the PDFs only showing up in the MAC. IllustratorSaveOptions(Extendscript) should work the same across both platforms, correct?
            • 3. Re: Problem with IllustratorSaveOptions not saving on Mac but work perfectly on Windows [extendscript]
              Muppet Mark Level 5
              It's NOT the case of the file system showing the file correctly… It is saved to the requested location… You are just overwriting it with the standard PDF… The supplied paths you defined are the same… Here I have just made a change to your code…
              var myDoc = app.activeDocument; // Just so I can ignore the rest of the code…
              if (myPermission){
              if (myFileName){
              else
              if (destFolder) {
              var IFile = new File(destFolder + '/' + myFileName + '.ai' );   // Now unique
                  with (ISave){
                  var pdfFile = new File(destFolder + '/' + myFileName + '.pdf' ); // Ditto here
                      with (pdfSave){
              var pdfFileCompressed = new File(destFolder + '/' + myFileName +'%2e' + 'now_format' + '.pdf' ); // This was just un-string your variable…
                  with (pdfSaveOpts){
              else {
              • 4. Re: Problem with IllustratorSaveOptions not saving on Mac but work perfectly on Windows [extendscript]
                duhwellhuh Level 1
                Hey Muppet, thanks for the input. It seems like that will work. I will have to try it today at work and see how it goes. Another question: How would I go about wrapping this in a function so that at this point -
                else
                alert ("Save cancelled"); the script would totally stop. I'm doing alot of my debugging in ESTK, and when I hit the cancel button, this alert does pop up, but the script keeps running. It seems like that would end up wasting alot of memory. The only answer I've seen on other forums is to use RETURN to end the script, and it has to have a function. Thanks in advance!
                • 5. Re: Problem with IllustratorSaveOptions not saving on Mac but work perfectly on Windows [extendscript]
                  Muppet Mark Level 5
                  Yeah… For AI, ID & PS I wrap everything in function calls so that I can just return; and end the script… ID does have a exit(); but as its the only app with this I just stick to what I use everywhere else… Keeps all my variables from being global too… I usually do stuff like
                  function doStuff() {
                      if ( app.documents.length == 0 ) { return; }
                      // Set up function variables if there is a doc
                      var doc, count, etc;
                      // Do the rest of my stuff
                  doStuff();
                  I don't let anyone know they just cancelled… Surely they know that already…?
                  • 6. Re: Problem with IllustratorSaveOptions not saving on Mac but work perfectly on Windows [extendscript]
                    duhwellhuh Level 1
                    I guess you're right on letting them now they cancelled. I'll pull that from my script. I'll give all of this a shot in a bit. Thanks again.
                    • 7. Re: Problem with IllustratorSaveOptions not saving on Mac but work perfectly on Windows [extendscript]
                      duhwellhuh Level 1
                      You are the master of muppets! Once again, you came through with the right answer. Thanks!!  It works like a charm.
