4 Replies Latest reply on Mar 12, 2012 2:25 AM by Mylenium
    Unconstrained video format.
    Xingstarc
      I am currently working on a 3500x1000 video but I am unable to render it at full 3500x1000 pixel as most of the output format have been constrained to maximum of 1920x1080
      can anyone please help me with a setting that can compress the video into a good quality yet compressed video size? I have tried Quicktime compression but for 10 seconds, the video was like 600MB+
      I am using the video for a LED wall and using a Windows operating system (Dataton Watchout) as the player, I have tried to split the video into two 1750x1000 but there was delay between 2 videos when projected on the LED wall, and large video format will just slow down the system. My final solution was to create a 1920x1080 video and double it to 3500 pixels but I am avoiding to do so.
      Thanks in advance
      p.s. I have seen someone actually created a 3840x1080 quicktime video and then using a mac system to convert it into .mpeg video with 3840x1080. But I have no idea how it was done.
        • 1. Re: Unconstrained video format.
          Andrew Yoole MVP & Adobe Community Professional
          Render to a lossless format like Quicktime Animation (100% quality) from After Effects.  Then compress using another compression tool:  Adobe Media Encoder, Apple Compressor, Quicktime Pro, Episode Pro etc.
          What is the the Watchout system driving - how many displays?  In what format/arrangement?  Typically, it's best to provide Watchout video in segments suitable for each output device, rather than one huge file on all devices.  The delay you experienced between files was probably the result of inadequate drive I/O speed.
          If, for example, the display is created using two parallel projectors at 1920x1080, you're far better off building your comp at the full resolution, then rendering two segments at the native resolution of the two projectors, taking overlaps etc into account.
          • 2. Re: Unconstrained video format.
            That was probably done using a custom MPEG CoDec, nothing whichg you can do in any of the Adobe tools. As for the rest, do as Andrew said. use an external converter and create e.g. a DivX file using their 4K preset. Whether or not this will actually play inside this particular software, I have no idea. In my world, this kind of stuff is usually done via synced harddisk recorders and a video splitter...
            Mylenium
            • 3. Re: Unconstrained video format.
              Xingstarc Level 1
              Thanks for the reply. Guess I have to find another compressor to do so, any recommendations?
              • 4. Re: Unconstrained video format.
                If you stick with my suggestion, you would require DivX Pro, which comes with a dedicated encoding app. Other than that you could try ProCoder. You may even get quite a bit with ffmpeg/MPEGStreamclip and one of its many derivatives. Just the same, you could use VirtualDub.
                Mylenium
