3 Replies Latest reply on Mar 13, 2012 5:30 AM by Sercan Altun
    Embeding symbols from a swf created with mxmlc
    Sercan Altun
      Hello everyone,
      I am trying to bundle my resources in seperate swf files then use them in another flex project. I create this bundles from a wizard i wrote in AIR. AIR app calls mxmlc to compile bundle.as and i dynamicaly load bundle.swf. I can access resources from this bundled swf using ApplicationDomain.getDefinition(). No problem there
      However i also want to use my wizard to edit prexisting bundles. Problem is i cannot embed resource from original bundle to new bundle. I mainly use Sprite and ByteArray assets in bundles.
      To simplfy problem i prepared following test. Created a bundle application to create bundle swf in flex. The project has 4 files: 2 .as files, 1 .png file, 1 .swf file( from FLA which has a symbol linked "Fill" )
      // Bundle.as
      package
                import flash.display.*;
                public class Bundle extends Sprite
                          public function Bundle()
                                    var fla:DisplayObject = new Fla();
                                    addChild(fla);
                                    var image:DisplayObject = new Image();
                                    addChild(image);
      // Image.as
      package
                import flash.display.Bitmap;
                [Embed(source='plus.png')]
                public class Image extends Bitmap
      // Fla.as
      package
                import flash.display.Sprite;
                [Embed(source='fla.swf', symbol="Fill")]
                public class Fla extends Sprite
                          public function Fla()
      Project above compiles without problem and i can see both assets on screen.
      Then i create a second project which will use swf created from project above.
      package
                public class Application extends Sprite
                          [Embed(source='Bundle.swf', symbol='Fla')]    /// Flex cannot embed this
                          private var flaClass:Class;
                          [Embed(source='Bundle.swf', symbol='Image')]  /// But it can embed this
                          private var imageClass:Class;
                          public function Application()
                                    var fla:DisplayObject = new flaClass();
                                    addChild(fla);
                                    var image:DisplayObject = new imageClass();
                                    addChild(image);
      The second project can only see Bitmap  asset as symbol. But could not find Sprite asset.
      We depend heavily on vector graphics from Flash, and byte array assets embeded with
       [Embed(source='x.ba', mimeType="application/octet-stream")]
      I could write byte array assets into a temp dir and embed them again but i cannot do it with Sprites. How can i solve this problem.
