5 Replies Latest reply on Mar 28, 2012 7:40 PM by JJMack
    Can anyone help?
    SADowdi
      Hello Everyone,
      I was curious about how I could get the photos aligned in this manner, and how could get that banner in the center with the text? I am using CS5. Any help would be greatly appreciated, thanks in advance.
      -S
        • 1. Re: Can anyone help?
          Curt Y Level 7
          You make a canvas of the correect size, by experimentation.  Use a white background.
          Then copy and pasts the imagaes to the canvas.  Use Ctrl T to resize each one and move in position.
          Then use the Text tool to write text.
          • 2. Re: Can anyone help?
            the_wine_snob Level 9
            Along with Curt's suggestion, I would also use Guides, to give you an idea of the areas that you will need to Transform (Free Transform) the Images to.
            • 3. Re: Can anyone help?
              c.pfaffenbichler Level 9
              The task is a better fit for a layout application like Indesign in my opinion.
              But if one insists on doing it in Photoshop and one wants to use a smaller image section I would recommend using Groups with Layer Masks or Vector Masks and putting one image in each and transforming it as a Smart Object.
              As for arriving at the necessary Selections or Paths one can start with Select All and then transform the Selection (Select > Transform Selection), enter the values in the Options Bar in percentages and set the Reference Point Location (also in the Options Bar) accordingly.
              • 4. Re: Can anyone help?
                SADowdi Level 1
                Thanks for your help everyone.
                -S
                • 5. Re: Can anyone help?
                  A rather simple Photoshop script I created for tileing image for printing then on roll paper might do. "PasteImageRoll.jsx" http://www.mouseprints.net/old/dpr/PasteImageRoll.html
                  // 2012  John J. McAssey (JJMack)
                  // This script is supplied as is. It is provided as freeware.
                  // The author accepts no liability for any problems arising from its use.
                  /* Help
                  <javascriptresource>
                  <about>$$$/JavaScripts/PasteImageRoll/About=JJMack's PasteImageRoll^r^rCopyright 2012 Mouseprints.^r^rCreate a document for printing on roll paper^rcan also be used as a wall hanging when^rall selected images have the same orientation.^rImages will be rotated to match cell orientation</about>
                  <category>JJMack's Collage Script</category>
                  </javascriptresource>
                  //Set Defaults here
                  var dfltRes = 300;          // default print DPI
                  var dfltCpys = 1;          // default image copies
                  var dfltPw  = 16;          // default roll paper width in inches
                  var dfltPl  = '';          // default roll paper length in feet. if set to null script will use 100 ft.
                  var dfltCw  = 4;          // default cell width in inches best if it divides paper with evenly.
                  var dfltCh  = 6;          // default cell height in inches
                  //End Defaults
                  var startRulerUnits = app.preferences.rulerUnits;
                  app.preferences.rulerUnits = Units.PIXELS; // tell ps to work with pixels
                  try {
                            // begin dialog layout
                            var RollPaperDialog = new Window('dialog');
                            RollPaperDialog.text = 'Paste Image Roll';
                            RollPaperDialog.frameLocation = [70, 70];
                            RollPaperDialog.alignChildren = 'center';
                            RollPaperDialog.PrintResPnl = RollPaperDialog.add('panel', [2, 2, 200, 56], 'Print Resolution');
                                      RollPaperDialog.PrintResPnl.add('statictext', [10, 16, 50, 48], 'DPI ');
                                      RollPaperDialog.PrintResPnl.docResEdt = RollPaperDialog.PrintResPnl.add('edittext', [50, 13, 90, 34], dfltRes, {name:'prtRes'});
                                      RollPaperDialog.PrintResPnl.docResEdt.helpTip = 'Image Resolution';
                                      RollPaperDialog.PrintResPnl.add('statictext', [96, 16, 140, 48], 'Copies ');
                                      RollPaperDialog.PrintResPnl.imgCpysEdt = RollPaperDialog.PrintResPnl.add('edittext', [140, 13, 175, 34], dfltCpys, {name:'imgCpys'});
                                      RollPaperDialog.PrintResPnl.imgCpysEdt.helpTip = 'Number of copies of selected Images';
                            RollPaperDialog.PaperSizePnl = RollPaperDialog.add('panel', [2, 2, 200, 56], 'Roll Paper Size');
                                      RollPaperDialog.PaperSizePnl.add('statictext', [10, 16, 50, 48], 'Width ');
                                      RollPaperDialog.PaperSizePnl.aspectWidthEdt = RollPaperDialog.PaperSizePnl.add('edittext', [50, 13, 90, 34], dfltPw, {name:'pprWth'});
                                      RollPaperDialog.PaperSizePnl.aspectWidthEdt.helpTip = 'Roll width in inches';
                                      RollPaperDialog.PaperSizePnl.add('statictext', [96, 16, 140, 48], 'Length ');
                                      RollPaperDialog.PaperSizePnl.aspectHeightEdt = RollPaperDialog.PaperSizePnl.add('edittext', [140, 13, 175, 34], dfltPl, {name:'pprLnth'});
                                      RollPaperDialog.PaperSizePnl.aspectHeightEdt.helpTip = 'Remaing roll length in feet';
                            RollPaperDialog.CellSizePnl = RollPaperDialog.add('panel', [2, 2, 200, 56], 'Tile Cell Size');
                                      RollPaperDialog.CellSizePnl.add('statictext', [10, 16, 50, 48], 'Width ');
                                      RollPaperDialog.CellSizePnl.aspectWidthEdt = RollPaperDialog.CellSizePnl.add('edittext', [50, 13, 90, 34], dfltCw, {name:'cllWth'});
                                      RollPaperDialog.CellSizePnl.aspectWidthEdt.helpTip = 'Width in inches';
                                      RollPaperDialog.CellSizePnl.add('statictext', [96, 16, 140, 48], 'Height ');
                                      RollPaperDialog.CellSizePnl.aspectHeightEdt = RollPaperDialog.CellSizePnl.add('edittext', [140, 13, 175, 34], dfltCh, {name:'cllHgt'});
                                      RollPaperDialog.CellSizePnl.aspectHeightEdt.helpTip = 'Height in inches';
                            var buttons = RollPaperDialog.add('group');
                            buttons.orientation = 'row';
                                                var okBtn = buttons.add('button');
                                      okBtn.text = 'OK';
                                      okBtn.properties = {name: 'ok'};
                                                var cancelBtn = buttons.add('button');
                                      cancelBtn.text = 'Cancel';
                                      cancelBtn.properties = {name: 'cancel'};
                            // display dialog and only continues on OK button press (OK = 1, Cancel = 2)
                            if (RollPaperDialog.show() == 1) {
                                      //variables passed from user interface
                                      var res                    = String(RollPaperDialog.PrintResPnl.prtRes.text);
                                      var copies          = String(RollPaperDialog.PrintResPnl.imgCpys.text);
                                      var pprwidth    = String(RollPaperDialog.PaperSizePnl.pprWth.text);
                                      var pprlength   = String(RollPaperDialog.PaperSizePnl.pprLnth.text); if (pprlength=='') { pprlength= 100; }
                                      var cellwidth   = String(RollPaperDialog.CellSizePnl.cllWth.text);
                                      var cellheight  = String(RollPaperDialog.CellSizePnl.cllHgt.text);
                                      var maxpaperwidth=pprwidth*res;                    // Printer Paper width in pixels inches*res
                                      var maxpaperlnth=pprlength*12*res;          // Printer Paper Roll length in pixels
                                      var width=cellwidth*res;                    // Document Cell width in pixels inches*res
                                      var height=cellheight*res;                    // Document Cell height in pixels inches*res
                                      var cols=0;                                        // Document number of columns will be determined by script using paper width and cell width
                                      var rows=0;                                        // Document rows will be determined by script using columns and # of images selected
                                      if (width>maxpaperwidth) { throw "error1"; }
                                      cols=Math.round((maxpaperwidth/width)-.499); //round down
                                      if (height>maxpaperlnth) { throw "error2"; }
                                      var file = new Array();
                                      file = app.openDialog();//opens dialog,choose images
                                      if (file.length<1) { throw "error3"; }
                                      rows=Math.round((file.length*copies/cols)+.499); //round up
                                      if (height*rows>maxpaperlnth) { throw "error4"; }
                                      var doc = app.documents.add(width*cols, height*rows, res);
                                      var currrow=0; var pasted=0;
                                      for (var i=0;i<file.length;i++) {
                                                app.load(file[i]); //load it into documents
                                                var backFile= app.activeDocument; //prepare your image layer as active document
                                                flatten(); //handle layered images
                                                if (backFile.width.value<backFile.height.value&&width>height ) { backFile.rotateCanvas(-90.0);  } // Rotate portraits
                                                if (backFile.height.value<backFile.width.value&&height>width ) { backFile.rotateCanvas(-90.0);  } // Rotate landscapes
                                                if (backFile.width.value/backFile.height.value > width/height) { backFile.resizeImage(null, height, null, ResampleMethod.BICUBIC); } // wider
                                                else {backFile.resizeImage(width, null, null, ResampleMethod.BICUBIC);} // same aspect ratio or taller
                                                backFile.selection.selectAll();
                                                backFile.selection.copy(); //copy resized image into clipboard
                                                backFile.close(SaveOptions.DONOTSAVECHANGES); //close image without saving changes
                                                for (var n=0;n<copies;n++) {
                                                          var x =pasted*width;
                                                          var y =currrow*height;
                                                          var selectedRegion = Array(Array(x,y), Array(x+width,y), Array(x+width,y+height), Array(x,y+height));
                                                          doc.selection.select(selectedRegion);
                                                          doc.paste(true); //paste image into masked layer your document
                                                          align('AdCH'); align('AdCV');
                                                          doc.selection.deselect();
                                                          pasted++
                                                          if ( pasted==cols ) { pasted=0; currrow++; }
                            else {
                                      //alert('Operation Canceled.');
                            // Return the app preferences
                            app.preferences.rulerUnits = startRulerUnits;
                  catch(err){
                            if (err=="error1") {alert("Paper width exceeded reduce the cell width");}
                            else if (err=="error2") {alert("Paper roll length exceeded reduce cell height");}
                            else if (err=="error3") {alert("No Images Selected");}
                            else if (err=="error4") {alert("Paper roll length exceeded try selecting fewer images or reducing cell height");}
                            // Lot's of things can go wrong, Give a generic alert and see if they want the details
                            else if ( confirm("Sorry, something major happened and I can't continue! Would you like to see more info?" ) ) { alert(err + ': on line ' + err.line ); }
                  // flatten Image
                  function flatten() {
                            try{
                                      executeAction( charIDToTypeID( "FltI" ), undefined, DialogModes.NO );
                            }catch(e){}
                  // Align Layers to selection
                  function align(method) {
                            var desc = new ActionDescriptor();
                            var ref = new ActionReference();
                            ref.putEnumerated( charIDToTypeID( "Lyr " ), charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ) );
                            desc.putReference( charIDToTypeID( "null" ), ref );
                            desc.putEnumerated( charIDToTypeID( "Usng" ), charIDToTypeID( "ADSt" ), charIDToTypeID( method ) );
                            try{
                                      executeAction( charIDToTypeID( "Algn" ), desc, DialogModes.NO );
                            }catch(e){}
