3 Replies Latest reply on Mar 12, 2012 11:15 AM by try67
    Using printerName in Javascript
    Davi A Level 1
      I am trying to use the "printerName:" command in Javascript. Here is what i have to work with..
      /* Print 1st Page */
      /* This sequence prints the first page of
      each document selected to the default printer.
      printParams: {
          printerName = "100C_01C155_HP4250"
      this.print
      bUI: false,
      nStart: 0,
      bSilent: true,
      bShrinkToFit: true,
      This will only print to the print queue that was last selected. I want it only utlize the printer specified. I also trying to make a print whole document to "said printer" script, instead of just first page to "said printer".
      Thanks in advance.
      Davi A
        • 1. Re: Using printerName in Javascript
          You have to specify the printParams parameter in the print() method, and
          provide to it the object you've created.
          Be aware that when doing so, all the other parameters are ignored.
          • 2. Re: Using printerName in Javascript
            Davi A Level 1
            I am still not clear on what I should do.   Truthfully this is my first go at writing java.
            I made a change but still same result...
            this.print
            bUI: false,
            nStart: 0,
            bSilent: true,
            bShrinkToFit: true,
            printParams: {
            printerName: "Office Printer 1"
            would "printParams" need to include "fileName ="? If so is there another way of going about it? also would i need to get rid of all the other parameters, that tell it to print what pages?
            • 3. Re: Using printerName in Javascript
              Here's the most basic way of using the PrintParams:
              var pp = this.getPrintParams();
              pp.printerName = "Office Printer 1";
              this.print(pp);
              You need to read up on the various possible options the PrintParams object
              offers in the Acrobat JavaScript API Reference.
