I'm running RH8 for Winhelp. this is a VERY old help project that's been updated many, many times over the years, but previously with no issues. I compile the project and the Error wizard shows several HC3025 errors, jumps to undefined topics. When I look at the resulting compiled help, the jumps to these topics are gone (broken?): "topic does not exist".
But, in the help project, i can do a Preview and the jumps appear fine, at least I get the window that says the there will be a link to topic x once the project is compiled. The topic IDs do exist, and they exist in the map file. but, in the map file, there are several map IDs preceded by a blue question mark. I don't know what that means, but it may be significant. Each of those topics also has a map # assigned.
How do I get RH to recognize the topics in the compiled help?
Thanks.-david s.
David S. I have the same problem and the same circumstances. If I copy a working popup to somewhere else in the document. The copied version is broken. I can't even create new popups. When I compile, the new popups are broken. I delete the RTF file and try again, same results. If I compile with the Microsoft Help Compiler outside of RoboHelp, all the links work just fine.
Thanks - Pam
