1. Re: Place image PS CS5 > ID CS5 HELP
P Spier Mar 12, 2012 2:22 PM (in response to auctioneer)First thing is View > Display Performance > High Quality Display (and you might want to reset that in the prefs -- default is typical, which is terrible). If that doesn't do it, the links are probably not up to date.
2. Re: Place image PS CS5 > ID CS5 HELP
auctioneer Mar 12, 2012 2:31 PM (in response to P Spier)Thanks Peter
I've checked links...no errors in ID
I have the setting on High Quality. Raster Images are still fuzzy.
If you look at the pdf you can easily see the problem. I'm still working on the issue and hoping I stumble across a resolution. If you can think of anything else, please let me know.
Thx
3. Re: Place image PS CS5 > ID CS5 HELP
P Spier Mar 12, 2012 2:35 PM (in response to auctioneer)do you have a specific page you want me to check? The ones I looked at other than the cover looked pretty good...
4. Re: Place image PS CS5 > ID CS5 HELP
auctioneer Mar 12, 2012 2:38 PM (in response to P Spier)Please look at the 'Casa Bella' page 5
5. Re: Place image PS CS5 > ID CS5 HELP
P Spier Mar 12, 2012 2:38 PM (in response to P Spier)Sorry, I take that back. I misunderstood where you said the callouts were made. They look fine, but the images themselves are not so hot.
What settings are you using to make the PDF? Looks like you might be down-sampling too much, or maybe the images aren't really large enough to use at the current scale. What's the "effective" ppi listed for them?
6. Re: Place image PS CS5 > ID CS5 HELP
auctioneer Mar 12, 2012 2:41 PM (in response to auctioneer)I don't anyone who uses ID or I would ask them. I would like to try and place the image (Casa Bella) and see if the results are the same at your end.. I can send you one small image to try if this would be ok.
7. Re: Place image PS CS5 > ID CS5 HELP
P Spier Mar 12, 2012 2:42 PM (in response to auctioneer)The images all appear to be downsampled to 72 ppi if they were over 100.
8. Re: Place image PS CS5 > ID CS5 HELP
I'm not sure waht you mean by the first part of the response. Are you using a pre-defined PDF export preset to make the PDF from ID, or some custom settings? What do you see on the compression page? I'm happy to look at an image, but out of context it might not tell us much. Do you know how to check the effective resolution? Select the image, and the effective PPI will be listed in both the Info Panel and the link info inthe bottom half of the Links panel.
9. Re: Place image PS CS5 > ID CS5 HELP
auctioneer Mar 12, 2012 2:47 PM (in response to P Spier)Casa Bella image: 1819 x 1394/10.18 mb/300ppi I've tried to modify the image, upsample-downsample, doesn't make any difference.
PDF export: PDF/X-4:2008 I've also tried many different setting but the results are the same. The native image when brought into ID changes, this is what I need to resolve.
Thanks again...
10. Re: Place image PS CS5 > ID CS5 HELP
auctioneer Mar 12, 2012 2:51 PM (in response to P Spier)I learn something everyday..thanks.
I checked the Links panel, this is the info for the Casa Bella images; ppi 300, effective ppi 181, size 1200-923 and if this helps the document is cymk.
11. Re: Place image PS CS5 > ID CS5 HELP
P Spier Mar 12, 2012 2:55 PM (in response to auctioneer)OK, you image is about 6 inches wide at 300 ppi, and it looks like you are using it at full size. According to Acrobat preflight, that image is less than 500 pixels wide, and only 72 ppi, in the PDF. That means either you are not using the PDF/X-4 preset, you've modified it to downsample, or there's a problem with how the image was brought into ID or it is out of date.
How do you get the images into your ID document?
12. Re: Place image PS CS5 > ID CS5 HELP
This means you're scaling up, more than I ouwld like to see for press, but should be fine for digital printing, but we need to figure out how the image went from 1200 pixels wide to about 450. I think it's most likely the export settings.
13. Re: Place image PS CS5 > ID CS5 HELP
auctioneer Mar 12, 2012 3:09 PM (in response to P Spier)Peter the pdf you downloaded from the site is downsampled (interactive) to keep the file size down. The images in the PDF/X-4:2008 are exactly the same, I can upload a copy to my server to view if necessary. The issue is the native ID file, the images are't right before I export.
When I bring the images in I always use the 'place' command.
Earlier you mentioned the links....how do I check to ensure this isn't the problem. I just assumed because the error panel in the left corner stated 'no errors' the doc was good to go, maybe I'm missing something here.
Thx
14. Re: Place image PS CS5 > ID CS5 HELP
P Spier Mar 12, 2012 3:16 PM (in response to auctioneer)When you look in the Links panel you shouldn't see any yellow warning triangles or red missing link dots.
Are all of the images scaled to the point where the effictive resolution is only 180 ppi? This is only about 60% of what I would like to see in print (offset) and would probably show up as slightly pixelated images on your printed pages using normal commercial printing parameters. It's low, too, for digital output, but not so low that I would expect noticeably poor image quality off a typical color copier.
15. Re: Place image PS CS5 > ID CS5 HELP
auctioneer Mar 12, 2012 3:39 PM (in response to P Spier)Thanks Peter
No yellow or red warning signals...all well in the links panel.
I just ran another export PDF/X-4: 2008 and the images are noticably better, they still look like *&^%$^ in ID, but I think this will get me by. I know for now and in the future I will be using the drawing tools in ID. I wish I had paid more attention in class and I wouldn't have to redraw 26 mantel spec pages. Anyway it's not the end of the world!
Thanks again for all your help. Have a GREAT day!
Bob
16. Re: Place image PS CS5 > ID CS5 HELP
P Spier Mar 12, 2012 3:46 PM (in response to auctioneer)You can add vector (drawing content) to your images in Photoshop, but if you do, you must leave those objects live (don't rasterize or flatten layers) and save the file as a Photoshop PDF for placing into ID. Even if the vector content is live in a .psd, it will be rasterized when placed int ID, and you never want that with things like thin lines or small type, so Photoshop PDF is the safe format when you've added that sort of content. Change the file extension to .pdp and preserve Photoshop edtiability when you save, and ID will know to open in Photoshop when you choose Edit Original.
17. Re: Place image PS CS5 > ID CS5 HELP
auctioneer Mar 12, 2012 3:48 PM (in response to P Spier)Good advice...thanks again!
